Clearpath Husky | Nvidia Jetson AGX Orin | Ouster | Phidgets | ZED2i | Fixposition | Hokuyo | ROS2 (Humble)
This post is a quick and compact guide for working with Husky (ROS2).
Husky Informative Links
Activate the robot by pressing the power button. The initialization process of the Husky, along with the Ouster, Phidgets IMU, and NVIDIA, may require up to a minute to commence. A green light signals that the MCU (Microcontroller Unit) has successfully initiated, established a connection with the onboard PC, and is ready to receive commands from the onboard PC.
To establish a remote connection to the robot via software, connect an Ethernet cable to the Ethernet port situated on the top of the robot. However, it is necessary to create a static connection on your PC for this purpose. You can accomplish this by following the steps outlined in the topic below.
Husky Static Network Connection
To create a static connection in your PC (not the Husky), in Ubuntu go to Settings → Network then click on + and create a new connection.
The second task is to put the Address IP as 192.168.131.52 (may differ from robot to robot) and the Netmask as 24.
Click save and restart your network. Next is to open up the Husky as shown, and connect the LAN cable to the robot.
The password is
mybotshop
Once connected, you can SSH into the robot which would provide the information
.-/+oossssoo+/-. root@ubuntu
`:+ssssssssssssssssss+:` -----------
-+ssssssssssssssssssyyssss+- OS: Ubuntu 22.04.6 LTS aarch64
.ossssssssssssssssssdMMMNysssso. Host: ITX
/ssssssssssshdmmNNmmyNMMMMhssssss/ Kernel: 5.10.120
+ssssssssshmydMMMMMMMNddddyssssssss+ Uptime: 38 mins
/sssssssshNMMMyhhyyyyhmNMMMNhssssssss/ Packages: 2917 (dpkg)
.ssssssssdMMMNhsssssssssshNMMMdssssssss. Shell: bash 5.0.17
+sssshhhyNMMNyssssssssssssyNMMMysssssss+ Terminal: run-parts
ossyNMMMNyMMhsssssssssssssshmmmhssssssso CPU: ARMv8 rev 1 (v8l) (8) @ 1.728GHz
ossyNMMMNyMMhsssssssssssssshmmmhssssssso Memory: 2354MiB / 62800MiB
/sssssssshNMMMyhhyyyyhdNMMMNhssssssss/
+sssssssssdmydMMMMMMMMddddyssssssss+
/ssssssssssshdmNNNNmyNMMMMhssssss/
-+sssssssssssssssssyyyssss+-
.-/+oossssoo+/-.
Network Configuration
Interface: lo
IPv4 Address: 127.0.0.1/8
IPv6 Address: ::1/128
Interface: dummy0
IPv4 Address:
IPv6 Address:
Interface: eth0
IPv4 Address: 192.168.131.2/24
IPv6 Address: fe80::344d:5c52:9e25:614c/64
Interface: wlan0
IPv4 Address: 192.168.0.200/24
IPv6 Address: fe80::f742:483:8d7f:d6c0/64
Interface: l4tbr0
IPv4 Address:
IPv6 Address:
Interface: rndis0
IPv4 Address:
IPv6 Address:
Interface: usb0
IPv4 Address:
IPv6 Address:
Interface: docker0
IPv4 Address: 172.17.0.1/16
IPv6 Address:
Internet Status: Connected
DNS Servers: Servers:
192.168.0.1
robot_status
Husky IP: 192.168.131.1
Pswd: mybotshop
SSH: ssh -XC administrator@192.168.131.1
Nvidia IP: 192.168.131.4
Pswd: mybotshop
SSH: ssh -XC administrator@192.168.131.4
Ouster IP: 192.168.131.20
Hokuyo IP: 192.168.131.21
Fixposition IP: 192.168.131.25
Husky Startup
Robot start: sudo service clearpath-robot start
Robot stop: sudo service clearpath-robot stop
Robot restart: sudo service clearpath-robot restart
Robot status: sudo service clearpath-robot status
Augments status: sudo service hsky status
SLAM: ros2 launch hsky_nav2 slam.launch.py
Map Navi: ros2 launch hsky_nav2 map_navi.launch.py
Odom Navi: ros2 launch hsky_nav2 odom_navi.launch.py
Visualization: ros2 launch hsky_viz view_robot.launch.py
Rebuild package: colcon build --symlink-install
Note: in case you cannot ping the husky the ssh client may be missing in your pc. It can be installed via
sudo apt-get install openssh-server
Husky Screen Connection
An alternative for connecting to the Husky is by plugging in an HDMI cable as well as a mouse and keyboard.
Husky PC DHCP
mybotshop
Network
Device | Network | Password |
Main PC | 192.168.131.1 | mybotshop |
Ouster LIDAR | 192.168.131.20 | - |
Hokuyo | 192.168.131.21 | - |
Fixposition | 192.168.131.25 | - |
NVIDIA Orin | 192.168.131.4 | mybotshop |
Husky Software
The drivers configured by MYBOTSHOP for the Husky can be found in the ros2_ws. Within the src folder, the third_party directory includes drivers for the Husky, as well as additional sensors like the Ouster, Hokuyo, Fixposition, and Phidgets IMU.
If you need to configure auxiliary sensors, the provided link offers valuable information, particularly for ROS2 and navigation. As user requirements can vary, the default setup has been maintained, allowing users to specify their parameters within their custom package.
Husky Start-up Job
The start-up job is available for both the main PC and NVIDIA. In the main PC, the startup job launches three main items:
- Husky base drivers
- Hokuyo Lidar
- Ouster Lidar
- Fixposition
In the secondary NVIDIA , the startup job launches ZED2i on startup:
.ossssssssssssssssssdMMMNysssso. Host: Jetson AGX Orin Developer Kit
/ssssssssssshdmmNNmmyNMMMMhssssss/ Kernel: 6.0.120-tegra
.-/+oossssoo+/-.
Interface: lo
Interface: dummy0
IPv4 Address:
IPv6 Address:
Interface: eth0
Interface: wlan0
Interface: l4tbr0
IPv4 Address:
IPv6 Address:
Interface: rndis0
IPv4 Address:
IPv6 Address:
Interface: usb0
IPv4 Address:
IPv6 Address:
Interface: docker0
IPv6 Address:
192.168.0.1
robot_status
"Husky IP: 192.168.131.1 "
"Pswd: mybotshop "
"SSH: ssh -X administrator@192.168.131.1 "
Husky Startup "
"ROS status: sudo service ros2 status "
"ROS start: sudo service ros2 start "
"ROS stop: sudo service ros2 stop "
"ROS restart: sudo service ros2 restart "
"Rebuild package: colcon build --symlink-install "
The launch file system.launch.py
in the ros2_ws
package of hsky_bringup
includes everything that is being launched at the startup. The startup job and its content can be verified in the directory /etc/ros/humble
, here the original launch file will be copied.
Here’s what the different markers signify:
- Red Marker: Indicates a failed startup job.
- Green Marker: Indicates normal functioning.
- Grey Marker: Indicates the service hasn’t started yet.
In case of a red or grey marker, you can attempt to restart the service using:
Ouster/Hokuyo
lidar
The Husky model provided comes equipped with two distinct lidars: the Hokuyo-Ust10
and the Ouster OS1-32,
both of which are integrated into the system. To receive data from these lidars, it is necessary to run the corresponding drivers. This can be achieved using the following command:
ros2 launch hsky_lidar system.launch.py
Instructions for use are given in:
Zed2i
For the Zed2i, an onboard Nvidia AGX Orin is installed. The drivers are commonly built and provided in the third_party
in the ros_nv_ws. If you have dis-plugged the camera, be sure to re-attach it USB3.0 otherwise it does not detect the camera. Instructions for use are given in:
Fixposition
This Husky also comes with a Fixposition which is used for GPS localization. The topics are starting with ‘/fixposition/’ .
Phidgets IMU
The provided Husky has a phidgets IMU integrated into it. The parameters for odometry can be tuned in the folder ros2_ws/src/mybotshop/hsky_control/config/localization.yaml
Autonomous Navigation
Odom Navigation
To perform odometry based navigation, execute the command:
This command lets you navigate the robot in the global frame of map
Map Navigation
To initiate map-based navigation, the process involves mapping the environment first, followed by waypoint navigation. Here are the steps to achieve this:
- Start creating a map by executing the SLAM navigation command:
- Simultaneously, in a separate terminal, launch the visualization command to observe the map being constructed:
Utilize the joystick controller to navigate and create the map. Once satisfied with the map, export it using this command in one of the Jackal’s terminals:
ros2 run nav2_map_server map_saver_cli -f /home/administrator/ros2_ws/src/mybotshop/hsky_nav2/maps/custom_map
After saving the map, rebuild the packages to incorporate the new map:
colcon build --symlink-install --cmake-args -DCMAKE_BUILD_TYPE=Release
Upon successful rebuilding, in one terminal, launch the map navigation command to load the saved map:
Finally, in a separate terminal, execute the visualization command to visualize and control the robot via rviz:
Parameter Configuration
In the hsky_nav2
package, in the config
folder, the parameters can be adjusted for further requirements. What is provided is just a minimal configured setup and it is recommended to adjust the parameters.
Issues
Incase of questions please contact support@mybotshop.de. For issues related to the software please attach a ros2 bag e.g.
ros2 bag record -a
