[Clearpath Husky] Update Husky (ORIN AGX) to ROS2, no MCU Connection
I have tried to update our Husky A200 (ORIN AGX, Jetpack version unknown) to Ros2 using the online manual (Robot Installation | Clearpath Robotics Documentation).
Now I have the problem that I seem to have no connection to the installed microcontroller, I only see the following ROS Topics:
administrator@ubuntu:~$ ros2 topic list
/a200_0000/cmd_vel
/a200_0000/diagnostics
/a200_0000/joy_teleop/cmd_vel
/a200_0000/joy_teleop/joy
/a200_0000/joy_teleop/joy/set_feedback
/a200_0000/platform/cmd_vel_unstamped
/a200_0000/platform/emergency_stop
/a200_0000/platform/joint_states
/a200_0000/platform/odom
/a200_0000/platform/odom/filtered
/a200_0000/platform/wifi_connected
/a200_0000/platform/wifi_status
/a200_0000/robot_description
/a200_0000/sensors/lidar2d_0/diagnostics
/a200_0000/sensors/lidar2d_0/laser_status
/a200_0000/sensors/lidar2d_0/scan
/a200_0000/sensors/lidar3d_0/diagnostics
/a200_0000/sensors/lidar3d_0/scan
/a200_0000/sensors/lidar3d_0/velodyne_packets
/a200_0000/sensors/lidar3d_0/velodyne_points
/a200_0000/set_pose
/a200_0000/tf
/a200_0000/tf_static
/a200_0000/twist_marker_server/cmd_vel
/a200_0000/twist_marker_server/feedback
/a200_0000/twist_marker_server/update
/parameter_events
/rosout
administrator@ubuntu:~$ ros2 node list
/a200_0000/ekf_node
/a200_0000/joy_node
/a200_0000/namespaced_base_link_static_tf
/a200_0000/namespaced_odom_static_tf
/a200_0000/robot_state_publisher
/a200_0000/sensors/camera_0/camera
/a200_0000/sensors/lidar2d_0/urg_node
/a200_0000/sensors/lidar3d_0/velodyne_driver_node
/a200_0000/sensors/lidar3d_0/velodyne_laserscan_node
/a200_0000/sensors/lidar3d_0/velodyne_transform_node
/a200_0000/teleop_twist_joy_node
/a200_0000/transform_listener_impl_aaaadb488550
/a200_0000/twist_mux
/a200_0000/twist_server_node
/a200_0000/wireless_watcher
According to the online API (ROS 2 MCU API | Clearpath Robotics Documentation), MCU and Motor Topics should also appear here.
Since we have upgraded another PC, the installation of the update did not work as described in the manual because the following command does not work (sudo apt install ros-humble-clearpath-robot). My guess is that this package is not yet available for arm64. So I installed ROS2 itself and compiled the package myself.
Unfortunately I don’t know how to connect to the MCU. Do you have a manual or can you help me?
Edit:
unfortunately i can’t tell which Jetpack version we have or if it is installed at all, on “sudo apt-cache show nvidia-jetpack” i only get “no packages found”.
Update:
if i run “ros2 run micro_ros_agent micro_ros_agent serial --dev /dev/ttyUSB0 -v6” i only get a init and a set_verbose_level and no create_client:
[1698311799.798886] info | TermiosAgentLinux.cpp | init | running…
| fd: 3
[1698311799.799341] info | Root.cpp | set_verbose_level | logger setup
| verbose_level: 6
Dear @Felix1,
This manual is for the Jackal and is not applicable to the Husky. Instructions for upgrade are docs. To my knowledge there is no microros running for the Husky, and it should work directly once the packages are installed and the udev rules as well.
Hello @Sohail ,
i don’t see where it says it just for the Jackal but the linked Instructions from you workt.
Thanks very much :slight_smile:
Hello @Sohail ,
i’ve just noticed i don’t have a topic that shows me the current battery voltage (im pretty sure i could see this in ros1 under a topic called power or something like this) and also the /e_stop topic is always empty even if i push the e-stop button.
The topics and nodes i have are:
administrator@ubuntu:~ros2 topic list
/cmd_vel
/diagnostics
/dynamic_joint_states
/e_stop
/husky_velocity_controller/cmd_vel_unstamped
/husky_velocity_controller/odom
/husky_velocity_controller/transition_event
/imu/data
/joint_state_broadcaster/transition_event
/joint_states
/joy_teleop/cmd_vel
/joy_teleop/joy
/odom
/odometry/filtered
/parameter_events
/robot_description
/rosout
/set_pose
/tf
/tf_static
/twist_server/feedback
/twist_server/update
/controller_manager
/ekf_node
/joy_teleop/joy_node
/joy_teleop/teleop_twist_joy_node
/rqt_gui_py_node_3683
/transform_listener_impl_aaaad9cc9740
/twist_mux
/twist_server_node
I don’t know if I’m missing even more.
Do you have any idea what could be the Problem? Or do you know how the communication beween ros and the MCU is handled?
The battery voltage should be coming in the diagnostics. As for the e_stop, it might be that there is some issue in the Clearpaths port to Humble. If you can verify the issue, it would be worth submitting a bug report to their driver repository.
I’ve outputed around 1000 messages via ros2 topic echo /diagnostics >file.txt and i only have twist_mux and ekf_node messages.
So i don’t have any battery messages.
Have you seen any Topics or Nodes missing in the list?
You are correct, I have tested myself and it does not show, I have added a ticket to their github repo.
Hello @Sohail,
i have seen your ticket and the answer of tonybaltovski on Github.
Sadly i dont have a clue how to install the GitHub - clearpathrobotics/clearpath_common package he mentions. It dosn’t have a “husky_bringup install” like in the
you have given me or a install file in general.
The documentation he links explains how to install “sudo apt install ros-humble-clearpath-robot”. This is the Package i tried first and had the Problem that led to me making this thread and i’ve tried it again with the same result.
Hi @Felix1,
The clearpath guys have shifted their entire design process for ROS2. In addition to installing clearpath common you have to install clearpath robot and follow this docs.
Hello @Sohail,
the docs
you’ve linked me are the same as i had in the begining.
I’ve testet it once again by installing the skript (https://raw.githubusercontent.com/clearpathrobotics/clearpath_computer_installer/main/install.sh). Because i have an arm based Computer it couldn’t install “ros-humble-clearpath-robot”. So i’ve donwloaded it from git and compiled it myself. All the other Packages from the script could be installed without problems.
After the installation i’ve rebooted but i still had no connection to the MCU.
The “COMM” Led at the back of the Husky is red and nothing gets published in the Topics like /emergency_stop.
I had these Topics and nodes but most Topics are empthy:
/a200_0000/cmd_vel
/a200_0000/set_pose
/a200_0000/tf
/parameter_events
/rosout
/a200_0000/ekf_node
/a200_0000/joy_node
/a200_0000/transform_listener_impl_aaaadb93aa30
I also downloaded and compiled the GitHub - clearpathrobotics/clearpath_common package because it was mentioned in the github issue you’ve created but it doesn’t change anything.
Dear @Felix1,
Could you message me your email, I will contact Clearpath with you in CC.
