Jackal-Ouster-Zed
This post is a quick and compact guide for working with the Jackal.
The Jackal (differential robot) is an indoor compact development platform of the Canadian manufacturer Clearpath Robotics. ROS Noetic is commonly pre-installed in this unit.
Jackal Informative Links
The robot is turned on via the power button, and the start-up of the Jackal with the ouster and zed2 may take up to a minute to start.
The green light in the M means that the MCU has successfully started, and the directional arrows mean that it is now able to receive commands from the on-board PC.
Depending on the configuration of the Jackal, auxiliary sensors software drivers such as LiDar may start with the robot but often do not run as disconnection or damage of the wire of the sensor can cause the robot to not startup.
For software remote connection, the robot has to be accessed once to configure the WiFi network. Configuration can take place in one of two methods, the first being via the static network connection and the second being through the screen, where the screen method is much quicker and easier for clients to set up.
Jackal Static Network Connection
To create a static connection in your own PC (not the Jackal), in Ubuntu go to Settings → Network then click on + and create a new connection.
Click save and restart your network. Next is to open up the Jackal as shown, and connect the LAN cable to the robot.
The password is
clearpath
Note:
Some of the Jackals have the default DHCP connections. For these cases, you may either use the second method of connecting to Jackal as mentioned below or not make a static connection and just run the command nmap -sP 192.168.0.*`. This command will scan all available networks in the range of .0. Once you’ve identified the network of the Jackal, you can connect via ssh.
Jackal Screen Connection
An alternative for connecting to the Jackal is by plugging in an HDMI cable as well as a mouse and keyboard. This will allow you to connect the Jackal to your own local WiFi network and then you can connect later over the WiFi.
Jackal PC
clearpath
Network
This robot has an industrial-grade computer on board with the MCU port being on 192.168.131.1, and the Hokuyo Lidar port being on 192.168.132.1.
| Device | Network |
| Jackal | 192.168.131.1 |
| Ouster Lidar | 192.168.132.2 |
Jackal Software
The Jackal drivers configured by MYBOTSHOP are located in the catkin_ws. In the src folder, the third_party contains the drivers for the Jackal as well as any auxiliary sensors such as the Ouster Lidar and ZED2 camera.
For a configuration of auxiliary sensors, the following link provides useful information, especially for navigation. As requirements vary from user to user, the setup has been left as default and the users can specify their own parameters in their own custom package.
Start-up Job
The Jackal ordinarily utilizes Clearpath startup job unless otherwise specified. In case there is an issue with the robot not starting up. One can ssh into the Jackal and verify if the startup job is working correctly.
sudo service mbs_jackal status
The red marker in the service indicates that the startup job has failed. Green indicates everything is working correctly. Grey indicates that the service has not started yet. In case of red or grey marker, you may restart the service via:
sudo service mbs_jackal restart
The launch file mbs_jackal.launch includes everything which is being launched at the startup (Located in mbs_jackal_startup). This file can be updated to include all the nodes needed to run at the startup (e.g. your own packages). Once you add your custom node or launch files in the mbs_jackal.launch, you will need to run the following script so that it updates the start-up job on Jackal’s PC; to run with the newly updated mbs_jackal.launch.
rosrun mbs_jackal_startup startup_script.sh
Ouster Lidar
The Lidar drivers are started via:
roslaunch mbs_ouster ouster.launch
Configuration is available in the mbs_ouster/ouster.launch file.
ZED2
For the ZED2, an onboard Nvidia Graphics card is installed. The drivers are commonly built and provided in the third_party in the catkin_ws. Depending on the version of the ZED2 camera, you may launch the following:
roslaunch zed_wrapper zed2.launch
roslaunch zed_wrapper zed2i.launch
roslaunch zed_wrapper zed_no_tf.launch
If you have dis-plugged the camera, be sure to re-attach it USB3.0 otherwise it does not detect the camera.
Instructions for use are given in:
Debugging Controller
