Hi, I am using unitree go2 edu version. And while reinstalling jetpack using sdk manager, There was some issue. In the document I have to do enter recovery mode by connecting the FC REC and GND pins. Where is the FC REC and GND pin?
I found the information through below document.
@dongjukim The manufacturer does not recommend upgrading the NVIDIA board yourself. Additionally, they do not disclose any information about the board to us. As a result, I’m very sorry, but we are unable to assist you with this matter.
We also want to reflash the NVIDIA Board, but didn’t get any help. Can mybotshop provide/create a Jetpack 6 image to flash the SSD, since it’s not possible to flash the board using the SDK Manager?
@roco-kit To my knowledge, upgrading to Jetpack 6 means upgrading the OS from 20.04 to 22.04, which Unitree does not recommend due to which we also do not try to update the jetpack on Go2-EDU.
I’ll created a clonezilla dump file from my Go2 EDU Jetson and already restored it to an other ssd and the jetson ist working on my copy. If it’s allowed, i can upload this dump somewhere. @Azib@Sohail
Hi @silviapoli
i don’t know anytthing about the restoring of an official unitree backup. i just did my own backup before pocking arround with the jetson, removed the original nvme-ssd, ( put it on a save place ) restored my backup to another nvme-ssd an put the new one in the jetson.
I did my backup of the orginal nvme in an normal pc whitch has an nvme slot where i put the original jetson nvme inside and booted up clonezilla from an usb stick.
Hello. If it’s not too much trouble, could you share an image for the Nvidia Jetson Nano? I need to restore it to as close to the factory state as possible. I couldn’t restore the image from the official Unitree documentation.
Hello, everyone.
Does anyone have a backup image of the Orin Nano?
I have tried to follow the instructions to restore the SSD on my Jetson Orin according to the [Unitree support forum](https://support.unitree.com/home/en/developer/module_update), but I have been unable to do so. My Orin Nano will not boot the Ubuntu system in any way. Furthermore, when following the procedure, an error message appears at the end saying that the image is corrupted and may not have been recorded correctly.
In the Google Drive where Unitree has posted the backups, there is only an update for the NX image.
I’m trying to upgrade my GO2-W to JetPack 6.2.1, but my unit will not go into recovery mode. I’m pulling power, holding the recovery button with a pin, then reconnecting power. Is that the process you used?
Hello @asser ,
Is the USB 3.2 port that the RealSense is connected to still working?
Since I installed the update, it has stopped working completely.
Many thanks!
Yes this is the same process that i have done may be to be sure just remove the cover of the Jetson to easily access the recovery pin and also make sure you are using the correct USB-C port
I have the same issue currently i will try solving it by following the official documentation link they have a section called " Expansion Dock Type-C repair method"
