[Starting a new thread as requested]
Currently, we’re still having issues when installing qre_go2 on both the Go2 and the Host.
Go2
After adding internet connectivity with a USB WiFi dongle and cloning the foxy-nvidia branch, we followed the instructions:
- Executed the go2_install.bash script
- Build the repo executing
colcon build --symlink-install
The compilation stops at the go2_examples with the error:
CMake Error at CMakeLists.txt:37 (find_package):
By not providing "Findgo2_srvs.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "go2_srvs",
but CMake did not find one.
Could not find a package configuration file provided by "go2_srvs" with any
of the following names:
go2_srvsConfig.cmake
go2_srvs-config.cmake
Add the installation prefix of "go2_srvs" to CMAKE_PREFIX_PATH or set
"go2_srvs_DIR" to a directory containing one of the above files. If
"go2_srvs" provides a separate development package or SDK, be sure it has
been installed.
Host Pc
We performed the following tasks:
- Cloned the foxy brach in
~/ros2_ws - Checked ros2 was unset
- build the DDS package executing
colcon build --packages-select cyclonedds - sourced both
install/setup.bashand/opt/ros/foxy/setup.bash - build (twice) executing
The compilation stops at the go2_base with the error:
CMake Error at CMakeLists.txt:43 (find_package):
been installed.```
