I am working on the development of Unitree Go2 EDU, and as I proceed, I would like to mount the MID-360 sensor. If I purchase the sensor separately, is there any way to obtain the cover/mounting platform that comes as an official option through other means?
The frame etc. won’t be available separately. We only have the LIDAR + Connector Cable + Frame as combination for sale. You can request a quote at sales@mybotshop.de
I see. Is it necessary for individuals to solder or perform similar operations on the connector cable? When considering installing it on the Unitree Go2 EDU, which port on the docking station should it be connected to? Also, should the power terminal be connected to the docking station as well?
you don’t need to solder etc. Everything what you need to use within minutes, will be delivered / included in the package.
The LiDAR is using a round special connector at the nvidia backpack
I apologize for asking multiple times, but if I own both the Go2 EDU and the MID360, is it correct to understand that what I need to prepare is a cable to connect the M12 Aviation connector and the M8 Aviation connector, as well as an attachment that acts as a base to fix the Go2 EDU and MID360?
@ume0315
Hello, I am in the same situation as you are. I have Unitree Go2 and Livox Mid360 both bought separately. Meaning I don’t have a metal case for lidar etc.
I see that the official answer is just trying to sell and not really answering your question.
I am interested whether you have managed to solve this issue.
