[Unitree GO2] EDU Teleop
Hello everyone,
I am planning to do teleop operation using keyboard on Unitree Go2. The qre_go2 repository has already implemented the same solution. What I am curious about is what topic of unitree is needed for this operation? I am aware it is mostly /cmd_vel ros topic.
❯ ros2 topic list
/api/assistant_recorder/request
/api/assistant_recorder/response
/api/audiohub/request
/api/audiohub/response
/api/bashrunner/request
/api/bashrunner/response
/api/config/request
/api/config/response
/api/fourg_agent/request
/api/fourg_agent/response
/api/gas_sensor/request
/api/gas_sensor/response
/api/gesture/request
/api/gpt/request
/api/gpt/response
/api/motion_switcher/request
/api/motion_switcher/response
/api/obstacles_avoid/request
/api/obstacles_avoid/response
/api/pet/request
/api/pet/response
/api/programming_actuator/request
/api/programming_actuator/response
/api/rm_con/request
/api/robot_state/request
/api/robot_state/response
/api/sport/request
/api/sport/response
/api/sport_lease/request
/api/sport_lease/response
/api/uwbswitch/request
/api/uwbswitch/response
/api/videohub/request
/api/videohub/response
/api/vui/request
/api/vui/response
/arm_Command
/arm_Feedback
/audiohub/player/state
/audioreceiver
/audiosender
/config_change_status
/frontvideostream
/gas_sensor
/gesture/result
/gnss
/gpt_cmd
/gptflowfeedback
/lf/battery_alarm
/lf/lowstate
/lf/sportmodestate
/lio_sam_ros2/mapping/odometry
/lowcmd
/lowstate
/multiplestate
/parameter_events
/pctoimage_local
/pet/flowfeedback
/programming_actuator/command
/programming_actuator/feedback
/public_network_status
/qt_add_edge
/qt_add_node
/qt_command
/qt_notice
/query_result_edge
/query_result_node
/rosout
/rtc/state
/rtc_status
/selftest
/servicestate
/servicestateactivate
/sportmodestate
/uslam/client_command
/uslam/cloud_map
/uslam/frontend/cloud_world_ds
/uslam/frontend/odom
/uslam/localization/cloud_world
/uslam/localization/odom
/uslam/navigation/global_path
/uslam/server_log
/utlidar/client_cmd
/utlidar/cloud
/utlidar/cloud_base
/utlidar/cloud_deskewed
/utlidar/grid_map
/utlidar/height_map
/utlidar/height_map_array
/utlidar/imu
/utlidar/lidar_state
/utlidar/mapping_cmd
/utlidar/range_info
/utlidar/range_map
/utlidar/robot_odom
/utlidar/robot_pose
/utlidar/server_log
/utlidar/switch
/utlidar/voxel_map
/utlidar/voxel_map_compressed
/uwbstate
/uwbswitch
/videohub/inner
/webrtcreq
/webrtcres
/wirelesscontroller
/wirelesscontroller_unprocessed
/xfk_webrtcreq
/xfk_webrtcres
I think the requests are sent from here and doesnt have a direct equivalend of cmd_vel as in ROS conventions.
So I have to send the keyboard commands as Twist message under /api/sport/request topic. Same like what has been implemented in qre_go2 repo under go2_control package for teleoperation.
Not exactly you can reference in the go2_platform src and include files on the format that has to be sent
