[Unitree Go2 EDU] Nvidia Orin dist-upgrade
We need to upgrade ROS2 from Foxy to (at least) Humble.
I’ve seen in other threads that flashing Jetpack using the standard Nvidia method doesn’t work.
Changing the apt source file while maintaining the same repo (i.e., https://mirrors.ustc.edu.cn/ubuntu-ports/ ) will work?
Regards
We recommend using distrobox for ROS2 Humble if possible, as flashing can void the warranty.
