[Unitree Go2 EDU] Jetson Wifi issue
Hello Everyone,
I have accessed the Jetson Orin NX using a remote desktop, I was trying to connect to wifi but I am not able to see the WIFI in settings at all? Any idea why? I think network manager is not installed, and I know without internet I won’t be able to do any sudo installation becuase it keeps giving an error. I am focusing on doing wireless connection of Go2 and my workstation. I believe the option I have is to put wifi stick or dongle but I would like to know I am right or wrong?
Could really use help and suggestions from all for wireless transmission using WIFI or any other means?
Dear @Shiv. The Orin in the GO2 generally doesn’t have a WiFi module installed, and it is recommended to use a dongle. You can check our forums for recommendations on the dongle to use.
To use wifi dongle do I need to install any drivers or dependencies or just plug & play setup?
It is just plug and play if you purchase the correct USB WiFi dongle
Can you please the recommended one other than this option TL-WN722N
What I know from unitree ugreen wifi dongle is also most suitable . Though any specific model ?
For anything other than this, you would have to test the dongle, as some require drivers installed for Ubuntu. We currently use this for testing.
If you find a much better plug-and-play WiFi dongle alternative, please post it as to help other people.
Sure thing.
Will post it if I find anything better.
