we bought the Unitree Go2 EDU Version with the extension pack/Nvidia Orin Nano 8 GB. We want to use the robot in a lecture and need the Python API for the Sport Client because students should be able to use it in a ROS 2 Python Node to move and rotate the robot as well as use some other special predefined moves.
However, we can’t install the official Python SDK (https://github.com/unitreerobotics/unitree_sdk2_python) or the ROS 2 package https://github.com/unitreerobotics/unitree_ros2 on the Nvidia Orin Nano 8 GB in the Extension pack.
When trying to build the SDK we get the following error and we already tried the bugfix mentioned in the repo regarding the cyclonedds path:
Obtaining file:///home/unitree/unitree_sdk2_python
Collecting cyclonedds==0.10.2
Using cached cyclonedds-0.10.2.tar.gz (156 kB)
Installing build dependencies ... done
Getting requirements to build wheel ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 /tmp/tmpyyyypabs get_requires_for_build_wheel /tmp/tmpo2jv0mx_
cwd: /tmp/pip-install-ou1fh3jo/cyclonedds
Complete output (1 lines):
Could not locate cyclonedds. Try to set CYCLONEDDS_HOME or CMAKE_PREFIX_PATH
ERROR: Command errored out with exit status 1: /usr/bin/python3 /tmp/tmpyyyypabs get_requires_for_build_wheel /tmp/tmpo2jv0mx_ Check the logs for full command output.
The advised bugfix we tried, as mentioned in the official repository:
cd ~
git clone https://github.com/eclipse-cyclonedds/cyclonedds -b releases/0.10.x
cd cyclonedds && mkdir build install && cd build
cmake .. -DCMAKE_INSTALL_PREFIX=../install
cmake --build . --target install
cd ~/unitree_sdk2_python
export CYCLONEDDS_HOME="~/cyclonedds/install"
pip3 install -e .
We already have access to the qre_go2 repository and can build it. However, we need a Python API or package because we want to use the Unitree Go2 in a lecture and it looks like there are only C++ packages installed.
I would appreciate your suggestions.
Kind regards
