Unitree Go2 Air has ssh access disable firmware ver 1.1.2. Only IP 192.168.123.161 is open but not port 22 (ssh) in this IP. In the IP 192.168.123.18 there are not open ports. With the robot reset, would it be possible that the IP 192.168.123.18 port 22 will be avaliable ?
The GO2 air has no docking board, and by default hass all programming features disabled. You would need to purchase GO2 EDU or GO2 X or one of their variants to actually ssh access or program on them. Also not the GO2 pro is not programmable.
