Hello everyone,
I’m trying to run the unitree_legged_real real.launch file on my local machine, connected via wifi to the Go1 robot, but apparently something is wrong here:
$ roslaunch unitree_legged_real real.launch ctrl_level:=highlevel
... logging to /root/.ros/log/18f9dffc-d69c-11ec-8609-e45f018678a5/roslaunch-devicename-228.log
Press Ctrl-C to interrupt
RLException: Unable to contact my own server at [http://192.168.12.1:33367/].
This usually means that the network is not configured properly.
A common cause is that the machine cannot connect to itself. Please check
for errors by running:
ping 192.168.12.1
For more tips, please see
http://wiki.ros.org/ROS/NetworkSetup
The traceback for the exception was written to the log file
So I checked the connection as told:
$ ping 192.168.12.1
PING 192.168.12.1 (192.168.12.1) 56(84) bytes of data.
64 bytes from 192.168.12.1: icmp_seq=1 ttl=64 time=3.40 ms
64 bytes from 192.168.12.1: icmp_seq=2 ttl=64 time=2.98 ms
64 bytes from 192.168.12.1: icmp_seq=3 ttl=64 time=3.47 ms
^C
--- 192.168.12.1 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2003ms
rtt min/avg/max/mdev = 2.984/3.285/3.469/0.214 ms
The connection to the roscore seems to be fine since I can view all the topics with rostopic list.
I am able to reach all the devices in the 192.168.123.0 network and I was able to run the example_walk from the SDK.
Does somebody know, what I’m doing wrong?
Thanks in advance!
