[Unitree Go1]Trying to install Zigbee2MQTT or deCONZ
Hey Sohail,
I was recently trying to get Zigbee2MQTT or deCONZ app installed on Go1 using LAN for internet connection for now. However, I remembered you instructing that never do sudo apt upgrade. So I did just sudo apt update not upgrade. But I am getting error in update and because of which I am unable to install anything.
Err:12 Index of /ubuntu xenial-security/main arm64 Packages
404 Not Found [IP: 91.189.91.83 80]
Fetched 108 kB in 3s (35.8 kB/s)
Reading package lists… Done
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages 404 Not Found [IP: 91.189.91.83 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
And I searched so solution to it was upgrading this package. However, I am not sure should I do it or not and how will it affect the robot.
Kind regards
Ravin
Hi @Ravin, You can update the individual package but not all the packages (especially of Nvidia). It should work in that case.
Hi @Sohail
I do sudo apt update and I get this in my log, can you tell me why is it so?
Hit:1 http://phoscon.de/apt/deconz generic InRelease
Hit:2 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
Get:3 http://security.ubuntu.com/ubuntu xenial-security InRelease [106 kB]
Hit:4 http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports bionic InRelease
Ign:5 http://security.ubuntu.com/ubuntu xenial-security/main arm64 Packages
Get:6 http://security.ubuntu.com/ubuntu xenial-security/main Translation-en [211 kB]
Get:7 http://security.ubuntu.com/ubuntu xenial-security/main arm64 DEP-11 Metadata [88.0 kB]
Get:8 http://security.ubuntu.com/ubuntu xenial-security/main DEP-11 48x48 Icons [27.5 kB]
Get:9 http://security.ubuntu.com/ubuntu xenial-security/main DEP-11 64x64 Icons [116 kB]
Hit:10 http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports bionic-security InRelease
Err:5 http://security.ubuntu.com/ubuntu xenial-security/main arm64 Packages
  404  Not Found [IP: 185.125.190.83 80]
Hit:11 http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports bionic-updates InRelease
Hit:12 http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports bionic-backports InRelease
Hit:13 http://mirrors.tuna.tsinghua.edu.cn/ubuntu-ports xenial InRelease
Ign:14 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu bionic InRelease
Hit:15 http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu bionic Release
Hit:17 https://repo.download.nvidia.com/jetson/common r32.5 InRelease
Get:18 https://repo.download.nvidia.com/jetson/t210 r32.5 InRelease [2,565 B]
Fetched 108 kB in 7s (16.2 kB/s)
Reading package lists... Done
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages  404  Not Found [IP: 185.125.190.83 80]
When looked online it says xenial is for Ubuntu 16.04 but Go1 Nvidia is having Ubuntu 18.04, so it should use bionic.
I am not quite sure as different batches of unitree go1 have versions. It might be worth trying to contact Unitrees support.
Ok, I will try to contact them, but can you please help me with the problem like to analyze what does this error actually mean and why am I getting this error while trying to run sudo apt update. Because if I am unable to do this I cannot install any new driver or application needed for further development. So can you tell me what exactly the error means and why am I getting it?
