[Unitree Go1] Changing Position of LiDAR sensor
Hey @Sohail,
I have changed the position of Hellious 16P LiDAR in Go1, and now I would like to change in it the urdf file too, but I am not sure how to do. I tried to manually change in go1_description/urdf/go1_with_LIDAR.urdf the xyz in but as soon as I sourced it my robot eventually lost its connection with all the legs and it wasn’t eevn able to stand up, later I restarted it and reverted the changes in file and its ok now. But I actually want to change the position of robosense and robosense_joint (platform on which lidar is mounted) and move it a bit forward. Can you please help me?
Regards
Dear @Ravin,
The robot should not shutdown in any event due to a change in the URDF. I would suggest use the bringup to first check it locally then upload to the robot with the final changes. The only thing that needs to change is the joints position.
Hey @Sohail,
ok, I will try changing the joint position. I thought there were stl files and all so we have an automatic was like solidworks or something. Using which I can change the position and it will auto generate the file.
