[Unitree G1 EDU] Climbing mode
Hello everybody,
After updating our robot to the latest firmware, a ‘Climb’ function became available in the application.
When you switch to this mode, you will see that the G1’s behaviour changes, with its legs moving up and down constantly. However, it is not actually possible to climb stairs. The robot just makes a lot of noise and stumbles. Furthermore, you can not go to any other mode than damping mode.
Has anyone else tried using the climb mode successfully?
Thanks in advance!
Best,
Alex
