[Unitree B2-W] - Software Update & MyBotshop Software
Dear all,
we just received the Unitree B2-W. We are following the mybotshop instructions listed here: B2 Network Interface | Unitree B2
Currently, we are struggeling to the following:
1.) Where do we get the software udpate files from?
2.) The access to the described “B2 web server” is not possible. The IP access (via LAN and WIFI) works, but it seems like the mybotshop software is not installed. Further, the folder “/opt/mybotshop/” is not existing on the machine.
Can you please describe, why this software is missing and why we cant follow the instruction?
Thanks for your feedback.
It seems the robot was directly shipped to you instead of passing through the engineering department to avoid a longer delivery time. So you would have to install the repository by yourself.
In this case please send an email to support@mybotshop.de with your order number and request for access to the qre_b2 repository.
https://github.com/MYBOTSHOP/qre_b2
From there, follow the installation instructions. Please read all the instructions first and then go through it. You would also need a usb wifi stick or internet cable from a router to get internet. Be wary of any errors and file paths must be correct.
