[Unitree B2-W] High / Low level
I would like to use B2-W for movements like:
  • raise one of its legs (front and also back) - can this be done with high level of Unitree SDK or no ?
  • change the Roll, Pitch, Yaw angles its facing like when in select mode from joystick control but now I would like to set it with some command via script. Is it possible with high level or do I need to go down to the low level joint control ? Could ROS repo be used for this ?
I have found BalanceStand. however it looks like this only works with standard B2 ?
Even though when sending services calls for VisualWalk it return -1. Could you explain why ? I have read that the robot is not in the right mode but I have tried to put it in AI and also sportmode.
Thank you for your answer
Standing in two feet. It should be possible from their SDK you can see their docs for more info on that.
It should be possible using the high-level sdk as well. You may have to look into included libraries of the sdk.
Balance stand is that when it gets up from the ground, it switches to RL self balancing mode not as in balancing on the front 2 wheels.
A.I and sports mode is highly dependent on the B2’s current firmware. In a few versions they arent and in some versions they are and in the latest versions they are combined.
