I recently purchased a B2-W and am looking to explore the basic capabilities before moving into dev work. I noticed the handstand capability in this doc and was wondering if that’s an off-the-shelf capability with the remote control, or do I need to start programming to get that functionality?
I am also having issues pairing the B2-W to my account on the mobile app as I don’t see it listed in the available robots. I have tried several mobile devices and many power cycles. Anything I might be overlooking in getting it set up? I can get basic functionality through the remote control, but would love to pair to the app as well.
Thanks in advance for helping with these newbie questions! Still trying to get a lay of the land in this new world.
It was a feature that could be used via the remote but has since been removed from the latest software. However, you can still perform it via programming.
Are you using the Unitree explore app which has h1/g1/b2?
Makes sense that they removed it. I will look forward to testing that our programmatically once I get into it.
And yes, I am using the Unitree Explore App. I have previously bound a G1 with no issues, but the B2 doesn’t show up for some reason. The app just looks for a robot to pair to but nothing ever appears. I’ve reached out to their support team but getting limited help thus far.
I am having the same issue. I paired b2 with the app but from certain point I lost connection to it, after trying several ways I can not find it when searching for robots as well.
@Garfiey This issue usually occurs when an older version of the robot is being used. Please download the app by scanning the QR code available here.
Additionally, try setting up the robot in Wi-Fi mode and check whether there is a newer firmware update from Unitree, as outdated firmware can also cause connectivity issues.
