I tried controlling my robot by using the control example in the A1 software guide, but a compile error occurred when using catkin_make in catkin_ws, so I can’t use a1_real with rosrun.
Here is what the guide says:
4.4.2 control examples
Here take low-level control as an example, and we need three terminals here. Firstly, copy a1_real to ~/catkin_ws/src, and compile it:
cd ~/catkin_ws
catkin_make
Terminal-1, run ‘lcm server’ in sdk:
sudo ~/unitree_legged_sdk/build/sdk_lcm_server_low
Terminal-2, run ros master node:
roscore
Terminal-3, run user logic with rosrun:
rosrun a1_real position_lcm_publisher
Here is the CMakeErrorLog:
Determining if the pthread_create exist failed with the following output:
Change Dir: /home/unitree/catkin_ws/build/CMakeFiles/CMakeTmp
Run Build Command:"/usr/bin/make" “cmTC_f623b/fast”
/usr/bin/make -f CMakeFiles/cmTC_f623b.dir/build.make CMakeFiles/cmTC_f623b.dir/build
make[1]: Entering directory ‘/home/unitree/catkin_ws/build/CMakeFiles/CMakeTmp’
Building C object CMakeFiles/cmTC_f623b.dir/CheckSymbolExists.c.o
/usr/bin/cc -o CMakeFiles/cmTC_f623b.dir/CheckSymbolExists.c.o -c /home/unitree/catkin_ws/build/CMakeFiles/CMakeTmp/CheckSymbolExists.c
Linking C executable cmTC_f623b
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_f623b.dir/link.txt --verbose=1
/usr/bin/cc -rdynamic CMakeFiles/cmTC_f623b.dir/CheckSymbolExists.c.o -o cmTC_f623b
CMakeFiles/cmTC_f623b.dir/CheckSymbolExists.c.o: In function main': CheckSymbolExists.c:(.text+0x14): undefined reference to pthread_create’
CheckSymbolExists.c:(.text+0x18): undefined reference to `pthread_create’
collect2: error: ld returned 1 exit status
CMakeFiles/cmTC_f623b.dir/build.make:97: recipe for target ‘cmTC_f623b’ failed
make[1]: *** [cmTC_f623b] Error 1
make[1]: Leaving directory ‘/home/unitree/catkin_ws/build/CMakeFiles/CMakeTmp’
Makefile:126: recipe for target ‘cmTC_f623b/fast’ failed
make: *** [cmTC_f623b/fast] Error 2
File /home/unitree/catkin_ws/build/CMakeFiles/CMakeTmp/CheckSymbolExists.c:
#include <pthread.h>
int main(int argc, char** argv)
(void)argv;
#ifndef pthread_create
return ((int*)(&pthread_create))[argc];
#else
(void)argc;
return 0;
#endif
Determining if the function pthread_create exists in the pthreads failed with the following output:
Run Build Command:"/usr/bin/make" “cmTC_b0f66/fast”
/usr/bin/make -f CMakeFiles/cmTC_b0f66.dir/build.make CMakeFiles/cmTC_b0f66.dir/build
Building C object CMakeFiles/cmTC_b0f66.dir/CheckFunctionExists.c.o
/usr/bin/cc -DCHECK_FUNCTION_EXISTS=pthread_create -o CMakeFiles/cmTC_b0f66.dir/CheckFunctionExists.c.o -c /usr/share/cmake-3.10/Modules/CheckFunctionExists.c
Linking C executable cmTC_b0f66
/usr/bin/cmake -E cmake_link_script CMakeFiles/cmTC_b0f66.dir/link.txt --verbose=1
/usr/bin/cc -DCHECK_FUNCTION_EXISTS=pthread_create -rdynamic CMakeFiles/cmTC_b0f66.dir/CheckFunctionExists.c.o -o cmTC_b0f66 -lpthreads
/usr/bin/ld: cannot find -lpthreads
CMakeFiles/cmTC_b0f66.dir/build.make:97: recipe for target ‘cmTC_b0f66’ failed
make[1]: *** [cmTC_b0f66] Error 1
Makefile:126: recipe for target ‘cmTC_b0f66/fast’ failed
make: *** [cmTC_b0f66/fast] Error 2
I hope you can help me with this problem.
