Hello guys, I made a node to let de go1 walk in a cricle, however after I kill the node with ctrl-c the robot keeps walking circles. Before I run my node I use roslaunch go1_bringup bringup.launch so my node can publish messages into the cmd_vel topic. this is my code:
#!/usr/bin/env python3
import rospy
from geometry_msgs.msg import Twist
def clean_shutdown():
#Stop robot when shutting down
msg.linear.x = 0.0
msg.angular.z = 0.0
pub.publish(msg)
print(pub)
print ("Go1 shutting down")
if __name__== "__main__":
rospy.init_node("walk_circle")
rospy.loginfo("walk_circle node has started.")
pub = rospy.Publisher("cmd_vel", Twist, queue_size=10)
rate = rospy.Rate(2)
msg = Twist()
while not rospy.is_shutdown():
msg.linear.x = 0.3
msg.angular.z = 1.5
pub.publish(msg)
rate.sleep()
rospy.loginfo("while loop exit")
rospy.signal_shutdown("Shutdown requested.")
clean_shutdown()
The clean_shutdown function does actually run when I press ctrl+c, but the updated node doesn’t seem to be being published. What I’m trying to do is make the go1 stop when killing the “walk_circle” node and in the future preferably with a command ofcourse.
