Quick Question About Nema 23 Stepper Motors
Hi all,
I’m planning a small CNC/3D-printer upgrade and considering Nema 23 stepper motors. Looking for quick practical input:
Common uses: CNC routers, larger 3D printers, laser cutters — good for higher torque needs.
Typical specs to watch: holding torque (e.g., 1–3 Nm), current rating (A/phase), step angle (usually 1.8°), and length (affects torque).
Drivers and power: pick drivers that match current (e.g., 2–4 A per phase) and a suitable supply voltage (24–48V for better performance). Use proper cooling and set motor current with the driver.
Mounting and coupling: ensure rigid mounts, choose appropriate shaft couplers, and check shaft diameter (6.35mm/8mm common).
Practical tips: use microstepping for smoother motion, tune acceleration/jerk to avoid missed steps, and match motor torque to your load (don’t undersize).
If you mention your machine size and required torque/speed, I can suggest specific motor sizes/part numbers.
