Weatherproofed Husky | Ouster | UM7 IMU
This post is a quick and compact guide for working with Husky which has been augmented sensors such as Ouster and UM7 IMU using ROS2(Humble)
Please note that on connection with the internet, the robot might move a bit due to Ubuntu 22.04 updating its time region syncing.
Informative Links
Husky ROS Cheat Sheet (Applicable to Noetic)
Powering On
The robot is turned on via the power button, and the start-up of the Husky may take up to a minute to start. The green light indicates that the MCU has successfully started and is now able to receive commands from the onboard PC.
For software remote connection, the robot may be accessed via an ethernet port located on top of the robot.
Teleop
ros2 run teleop_twist_keyboard teleop_twist_keyboard.py
Network
| Husky MCU | 192.168.131.1 | clearpath |
| Ouster | 192.168.131.20 | - |
| Router | 192.168.131.100 | clearpath |
Robot Interface
The network configuration can take place in one of two methods, the first being via the static network connection and the second being through the screen, where the screen method is much quicker and easier for clients to set up. Alternatively, the hotspot Husky-A200-2.4G or Husky-A200-5G can be used to connect with the robot.
Hotspot Network Connection
To connect via hotspot, please search for the SSID of Husky-A200-2.4G or Husky-A200-5G and connect to it. The password is:
clearpath
Once connected, you can interface and ssh into the robot via:
Static Network Connection
The password is
clearpath
Screen Connection
An alternative for connecting to the Husky is by plugging in an HDMI cable as well as a mouse and keyboard. This will allow you to connect the Husky to your own local WiFi network and then you can connect later over the WiFi.
Husky PC
clearpath
Please note not all Husky are shipped with the WLAN module.
Robot Software
The Husky drivers as well as custom drivers configured by MYBOTSHOP are located in the ros2_ws. In the src folder, the third_party contains the drivers for the Husky and other sensors.
As requirements vary from user to user, the setup has been left as default and the users can specify their own parameters in their own custom package. When connecting or ssh’ing to the robots pc, additional information regarding the robot will be displayed e.g.
Current PC: Husky
Husky IP: 192.168.131.1
Pswd: clearpath
Ouster IP: 192.168.131.20
Router IP: 192.168.131.100
Username: admin
Pswd: Admin123
Husky-Drivers
Husky status: sudo service hsky status
Husky start: sudo service hsky start
Husky stop: sudo service hsky stop
Husky restart: sudo service hsky restart
ros2 launch hsky_lidars system.launch.py # Ouster
ros2 launch hsky_viz view_robot.launch.py # Rviz2
Robot Startup
The startup job launches two main components:
- Husky base drivers
- UM7 IMU driver
The launch file system_bringup.launch in the ros2_ws package of hsky_bringup includes everything that is being launched at the startup.
The Husky ordinarily utilizes Clearpath startup job unless otherwise specified. In this robot, we have our own upstart job for the custom auxiliary drivers. In case there is an issue with the robot not starting up. One can ssh into the Husky and verify if the startup job is working correctly.
New launch files and nodes can be added to the startup job by inserting them into the system.launch.py launch file for PC startup. Once added Run the following in ros2_ws.
ros2 run hsky_bringup startup_installer.py
The configuration file is located in hxg_startup/config/setup.bash. The important information is that the variable HSKY_OUSTER_LASER=0 can be used to enable the roslaunch files. If the values of 0 are replaced by 1, it will enable the launch files for the ouster to turn on e.g. HSKY_OUSTER_LASER=1 (The file must also be source e.g.: source setup.bash). This will also enable it to start on the robot startup if the following command is executed.
Please note that it is not recommended to keep the sensors on as they take time to startup and cause the startup job to fail. If this happens you can simply restart the service. As described above.
Ouster (Lidar)
The Lidar drivers are started via:
UM7 (Inertial Measurement Unit - IMU)
The provided Husky has a IMU integrated into it. The parameters for odometry can be tuned in the folder ros2_ws/src/mbs/hsky_control/config/localization.yaml.
Issues
In case of questions please contact support@mybotshop.de. For issues related to the software please attach a ros bag e.g.
rosbag record -a
