Jackal-3D-SLAM
This post is a quick and compact guide for working with the Jackal.
The Jackal (differential robot) is an indoor compact development platform of the Canadian manufacturer Clearpath Robotics. ROS Noetic is pre-installed in this unit.
Jackal Informative Links
The robot is turned on via the power button, and the start-up of the Jackal with the ouster and zed2 may take up to a minute to start.
The green light in the M means that the MCU has successfully started, and the directional arrows mean that it is now able to receive commands from the onboard PC.
This Jackal comes installed with an Ouster LiDar. In cases, where the LiDAR or other auxiliary components are added to the robot startup job and have their cable removed can cause the robot to not startup.
For software remote connection, the robot has to be accessed once to configure the WiFi network. Configuration can take place in one of two methods, the first being via the static network connection and the second being through the screen, where the screen method is much quicker and easier for clients to set up.
Jackal Static Network Connection
To create a static connection in your own PC (not the Jackal), in Ubuntu go to Settings → Network then click on + and create a new connection.
Click save and restart your network. Next is to open up the Jackal as shown, and connect the LAN cable to the robot.
The password is
mybotshop
Note: Some of the Jackals have the default DHCP connections. For these cases, you may either use the second method of connecting to Jackal as mentioned below or not make a static connection and just run the command
nmap -sP 192.168.0.*. This command will scan all available networks in the range of .0. Once you’ve identified the network of the Jackal, you can connect via ssh.
Current PC: Jackal
Jackal IP: 192.168.131.1
Pswd: mybotshop
SSH: ssh -X administrator@192.168.131.1
Ouster IP: 192.168.131.20 (INFO: Default off)
Jackal Startup
JKL status: sudo service jkl status
JKL start: sudo service jkl start
JKL stop: sudo service jkl stop
JKL restart: sudo service jkl restart
Ouster-Driver: roslaunch jkl_lidars lidars.launch
Update startup: rosrun jkl startup_script.sh
Rebuild package: catkin build --cmake-args -DCMAKE_BUILD_TYPE=Release
Jackal Screen Connection
An alternative for connecting to the Jackal is by plugging in an HDMI cable as well as a mouse and keyboard. This will allow you to connect the Jackal to your own local WiFi network and then you can connect later over the WiFi.
Jackal PC
mybotshop
Network
This robot has an industrial computer on board with the MCU port being on 192.168.131.1.
| Device | Network |
| Industrial computer | 192.168.131.1 |
| Ouster | 192.168.131.20 |
Jackal Software
The Jackal drivers configured by MYBOTSHOP are located in the ros_ws.
For a configuration of auxiliary sensors, the following link provides useful information, especially for navigation. As requirements vary from user to user, the setup has been left as default and the users can specify their own parameters in their own custom package.
Start-up Job
The Jackal ordinarily utilizes Clearpath startup job unless otherwise specified. In case there is an issue with the robot not starting up. One can ssh into the Jackal and verify if the startup job is working correctly.
The red marker in the service indicates that the startup job has failed. Green indicates everything is working correctly. Grey indicates that the service has not started yet. In case of red or grey marker, you may restart the service via:
Debugging Controller
