Jackal-Nvidia-AGX
This post is a quick and compact guide for working with the Jackal.
The Jackal (differential robot) is an indoor compact development platform of the Canadian manufacturer Clearpath Robotics. ROS Noetic is commonly pre-installed in this unit.
Jackal Informative Links
The robot is turned on via the power button, and the start-up of the Jackal with the ouster and zed2 may take up to a minute to start.
The green light in the M means that the MCU has successfully started, and the directional arrows mean that it is now able to receive commands from the on-board PC/Nvidia.
Depending on the configuration of the Jackal, auxiliary sensors software drivers such as LiDar may start with the robot but often do not run as disconnection or damage of the wire of the sensor can cause the robot to not startup.
For software remote connection, the robot has to be accessed once to configure the WiFi network. Configuration can take place in one of two methods, the first being via the static network connection and the second being through the screen, where the screen method is much quicker and easier for clients to set up.
Jackal Static Network Connection
To create a static connection in your own PC (not the Jackal), in Ubuntu go to Settings → Network then click on + and create a new connection.
Click save and restart your network. Next is to open up the Jackal as shown, and connect the LAN cable to the robot.
The password is
clearpath
Note: Some of the Jackals have the default DHCP connections. For these cases, you may either use the second method of connecting to Jackal as mentioned below or not make a static connection and just run the command nmap -sP 192.168.0.*`. This command will scan all available networks in the range of .0. Once you’ve identified the network of the Jackal, you can connect via ssh.
Current PC: Jackal
Jackal IP: 192.168.131.1
Password: clearpath
Jackal-Drivers
Jackal status: sudo service mbs_jackal status
Jackal start: sudo service mbs_jackal start
Jackal stop: sudo service mbs_jackal stop
Jackal restart: sudo service mbs_jackal restart
View robot: roslaunch mbs_viz viz.launch
Jackal Screen Connection
An alternative for connecting to the Jackal is by plugging in an HDMI cable as well as a mouse and keyboard. This will allow you to connect the Jackal to your own local WiFi network and then you can connect later over the WiFi.
Jackal PC
clearpath
Network
This robot has an NVIDIA Jetson AGX computer on board with the MCU port being on 192.168.131.1.
| Device | Network |
| Nvidia | 192.168.131.1 |
Jackal Software
The Jackal drivers configured by MYBOTSHOP are located in the ros_ws.
For a configuration of auxiliary sensors, the following link provides useful information, especially for navigation. As requirements vary from user to user, the setup has been left as default and the users can specify their own parameters in their own custom package.
Start-up Job
The Jackal ordinarily utilizes Clearpath startup job unless otherwise specified. In case there is an issue with the robot not starting up. One can ssh into the Jackal and verify if the startup job is working correctly.
The red marker in the service indicates that the startup job has failed. Green indicates everything is working correctly. Grey indicates that the service has not started yet. In case of red or grey marker, you may restart the service via:
Debugging Controller
