HUSKY-NVIDIA_Nano-Phidgets_IMU-Ouster_Lidar-ZED2i-Hokuyo
This post is a quick and compact guide for working with Husky which uses an Nvidia Nano as the computing unit for processing Stereolabs Zed2i camera feed, Phidgets for orientation data and Hokuyo & Ouster lidar for obstical avoidence.
Informative Links
Husky ROS Cheat Sheet (Applicable to Noetic)
Powering On
The robot is turned on via the power button, and the start-up of the Husky may take up to a minute to start. The green light indicates that the MCU has successfully started and connected to the onboard PC and is now able to receive commands from the onboard PC.
For software remote connection, the robot may be accessed via ethernet port.
Teleop
Network
| Husky Wifi | Husky-A200-0952-2.4G | clearpath |
| Main PC | 192.168.131.1 | clearpath |
| Nvidia Jetson Nano | 192.168.131.2 | - |
| Hokuyo | 192.168.131.21 | - |
| Ouster OS1-32 | 192.168.131.20 | - |
Robot Interface
For software remote connection, the robot has to be accessed once to configure the WiFi network. This network configuration can take place in one of two methods, the first being via the static network connection and the second being through the screen, where the screen method is much quicker and easier for clients to set up.
Static Network Connection
The password is
clearpath
Screen Connection
An alternative for connecting to the Husky is by plugging in an HDMI cable as well as a mouse and keyboard. This will allow you to connect the Husky to your own local WiFi network and then you can connect later over the WiFi.
Husky PC
clearpath
Robot Software
The Husky drivers configured by MYBOTSHOP are located in the ros_ws. In the src folder, the third_party contains the drivers for the Husky.
As requirements vary from user to user, the setup has been left as default and the users can specify their own parameters in their own custom package. When connecting or ssh’ing to the robots pc, additional information regarding the robot will be displayed e.g.
Current PC: Husky
Husky IP: 192.168.131.1
Pswd: clearpath
Nvidia Nano IP: 192.168.131.2
Pswd: clearpath
Ouster IP: 192.168.132.20
Hokuyo IP: 192.168.132.21
WiFi IP: 192.168.131.100
Pswd: clearpath
Router Pswd: admin
Husky-Drivers:
Husky status: sudo service mbs_husky status
Husky start: sudo service mbs_husky start
Husky stop: sudo service mbs_husky stop
Husky restart: sudo service mbs_husky restart
View robot: roslaunch mbs_husky_viz viz.launch
Ouster driver:
Lidars driver: roslaunch mbs_lidar lidar.launch
Robot (Main-Pc) Startup
The start-up job is available for the main pc. The startup job launches two main components:
- Husky base drivers
- Phidgets IMU driver
The launch file system_bringup.launch in the ros_ws package of mbs_husky_startup includes everything which is being launched at the startup.
The Husky ordinarily utilizes Clearpath startup job unless otherwise specified. In this robot, we have our own upstart job for the custom auxiliary drivers. In case there is an issue with the robot not starting up. One can ssh into the Husky and verify if the startup job is working correctly.
New launch files and nodes can be added to the startup job by inserting them into the system_bringup.launch launch file for PC startup. Once added Run the following in ros_ws.
rosrun mbs_husky_startup startup_installer.py
Robot (Nvidia-Pc) Startup
Current PC: Nvidia
Pswd: clearpath
Pswd: clearpath
Pswd: clearpath
Router Pswd: admin
Husky-Drivers:
Husky status: sudo service nv_ros status
Husky start: sudo service nv_ros start
Husky stop: sudo service nv_ros stop
Husky restart: sudo service nv_ros restart
The start-up job is available for the Nvidia pc. The startup job launches one components i.e. Stereolabs ZED2i drivers which constently takes camear feedback sends it to the main pc.
In case there is an issue with the starting up. One can ssh into the Nvidia and verify if the startup job is working correctly.
Ouster/Hokuyo
lidar
The Husky model provided comes equipped with two distinct lidars: the Hokuyo-Ust10 and the Ouster OS1-32, both of which are integrated into the system. To receive data from these lidars, it is necessary to run the corresponding drivers. This can be achieved using the following command:
Phidgets IMU
The provided Husky has a phidgets IMU integrated into it. The parameters for odometry can be tuned in the folder ros_ws/src/mbs/mbs_control/config/wheel_localization_config.yaml.
visualization
To visualize all the data from the sensors, follow these steps:
- Start by running the lidar driver in a terminal.
- Next, open a new terminal and execute the “Rviz launch” file mentioned in the command below. By following these instructions, you will be able to visualize all the sensor data.
Issues
In case of questions please contact support@mybotshop.de. For issues related to the software please attach a ros bag e.g.
rosbag record -a
