I have a NVIDIA Jetson Orin Nano Dev Kit. It worked well for without any problem.
However, today I restarted the Jetson Orin from the console “sudo reboot”, it shut down, the fan turned of and nothing happened.
WHen cutting power, and connecting it again, only the green indicator light turns on, the fan remains off and i wont get a video out.
Does anybody have recommendations for fixing the not booting Jetson Orin Nano?
Usually, if it doesn’t boot up, it is due to a loose SSD / SD card, power, or corrupted OS. Could you try using a different SSD or SD Card to rule out the OS is not the issue?
Thanks for the response. However i have already tried your recommendation and even installed a new os (JetPack 5.1.3). I still get no sign of life of the board
same issue, have you successed?
