roslaunch-rasberrypi-1445.log:
[roslaunch][INFO] 2021-10-14 19:19:11,371: Checking log directory for disk usage. This may take awhile.
Press Ctrl-C to interrupt
[roslaunch][INFO] 2021-10-14 19:19:11,393: Done checking log file disk usage. Usage is <1GB.
[roslaunch][INFO] 2021-10-14 19:19:11,394: roslaunch starting with args ['/opt/ros/kinetic/bin/roslaunch', 'realsense2_camera', 'rs_camera.launch', 'enable_sync:=true']
[roslaunch][INFO] 2021-10-14 19:19:11,395: roslaunch env is {'NO_AT_BRIDGE': '1', 'ROS_DISTRO': 'kinetic', 'LC_NUMERIC': 'de_DE.UTF-8', 'LC_MEASUREMENT': 'de_DE.UTF-8', 'LESSOPEN': '| /usr/bin/lesspipe %s', 'XDG_SESSION_TYPE': 'tty', 'ROSLISP_PACKAGE_DIRECTORIES': '/home/pi/catkin_ws/devel/share/common-lisp', 'LOGNAME': 'pi', 'USER': 'pi', 'LC_ALL': 'en_US.UTF-8', 'LC_PAPER': 'de_DE.UTF-8', 'HOME': '/home/pi', 'CMAKE_PREFIX_PATH': '/home/pi/catkin_ws/devel:/opt/ros/kinetic', 'DISPLAY': 'localhost:11.0', 'LANG': 'en_US.UTF-8', 'TERM': 'xterm-256color', 'SHELL': '/bin/bash', 'ROS_LOG_FILENAME': '/home/pi/.ros/log/d8db13ba-2d12-11ec-9bc7-dca6327f86e2/roslaunch-raspberrypi-1445.log', 'LANGUAGE': 'en_US.UTF-8', 'LC_MONETARY': 'de_DE.UTF-8', 'LD_LIBRARY_PATH': '/usr/local/lib:/home/pi/catkin_ws/devel/lib:/home/pi/catkin_ws/devel/lib:/opt/ros/kinetic/lib', 'TEXTDOMAIN': 'Linux-PAM', 'ROS_MASTER_URI': 'http://localhost:11311', 'ROS_PYTHON_VERSION': '2', 'XDG_RUNTIME_DIR': '/run/user/1000', 'LC_ADDRESS': 'de_DE.UTF-8', 'PYTHONPATH': '/home/pi/catkin_ws/devel/lib/python2.7/dist-packages:/opt/ros/kinetic/lib/python2.7/dist-packages:/usr/local/lib', 'SHLVL': '1', 'ROS_ROOT': '/opt/ros/kinetic/share/ros', 'PATH': '/opt/ros/kinetic/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games', 'MAIL': '/var/mail/pi', 'PKG_CONFIG_PATH': '/home/pi/catkin_ws/devel/lib/pkgconfig:/opt/ros/kinetic/lib/pkgconfig', 'ROS_PACKAGE_PATH': '/home/pi/catkin_ws:/home/pi/catkin_ws/src/ddynamic_reconfigure:/home/pi/catkin_ws/src/realsense-ros/realsense2_camera:/home/pi/catkin_ws/src/realsense-ros/realsense2_description:/opt/ros/kinetic/share', 'XDG_SESSION_ID': 'c4', 'DBUS_SESSION_BUS_ADDRESS': 'unix:path=/run/user/1000/bus', '_': '/opt/ros/kinetic/bin/roslaunch', 'LC_IDENTIFICATION': 'de_DE.UTF-8', 'SSH_CONNECTION': '192.168.123.162 46366 192.168.123.12 22', 'LESSCLOSE': '/usr/bin/lesspipe %s %s', 'UNITREE_LEGGED_SDK_PATH': '/home/pi/unitree_legged_sdk', 'SSH_TTY': '/dev/pts/2', 'SSH_CLIENT': '192.168.123.162 46366 22', 'LC_TELEPHONE': 'de_DE.UTF-8', 'UNITREE_PLATFORM': 'amd64', 'PWD': '/home/pi', 'ROS_ETC_DIR': '/opt/ros/kinetic/etc/ros', 'XDG_SESSION_CLASS': 'user', 'ROS_VERSION': '1', 'LC_NAME': 'de_DE.UTF-8', 'ALIENGO_SDK_PATH': '/home/pi/aliengo_sdk', 'LC_TIME': 'de_DE.UTF-8', 'LS_COLORS': 'rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:'}
[roslaunch][INFO] 2021-10-14 19:19:11,395: starting in server mode
[roslaunch.parent][INFO] 2021-10-14 19:19:11,395: starting roslaunch parent run
[roslaunch][INFO] 2021-10-14 19:19:11,396: loading roscore config file /opt/ros/kinetic/etc/ros/roscore.xml
[roslaunch][INFO] 2021-10-14 19:19:12,884: Added core node of type [rosout/rosout] in namespace [/]
[roslaunch.config][INFO] 2021-10-14 19:19:12,885: loading config file /home/pi/catkin_ws/src/realsense-ros/realsense2_camera/launch/rs_camera.launch
[roslaunch][INFO] 2021-10-14 19:19:13,033: Added node of type [nodelet/nodelet] in namespace [/camera/]
[roslaunch][INFO] 2021-10-14 19:19:13,056: Added node of type [nodelet/nodelet] in namespace [/camera/]
[roslaunch][INFO] 2021-10-14 19:19:13,057: ... selected machine [] for node of type [nodelet/nodelet]
[roslaunch.pmon][INFO] 2021-10-14 19:19:13,059: start_process_monitor: creating ProcessMonitor
[roslaunch.pmon][INFO] 2021-10-14 19:19:13,060: created process monitor <ProcessMonitor(ProcessMonitor-1, initial daemon)>
[roslaunch.pmon][INFO] 2021-10-14 19:19:13,060: start_process_monitor: ProcessMonitor started
[roslaunch.parent][INFO] 2021-10-14 19:19:13,061: starting parent XML-RPC server
[roslaunch.server][INFO] 2021-10-14 19:19:13,061: starting roslaunch XML-RPC server
[roslaunch.server][INFO] 2021-10-14 19:19:13,061: waiting for roslaunch XML-RPC server to initialize
[xmlrpc][INFO] 2021-10-14 19:19:13,062: XML-RPC server binding to 0.0.0.0:0
[xmlrpc][INFO] 2021-10-14 19:19:13,062: Started XML-RPC server [http://raspberrypi:33859/]
[xmlrpc][INFO] 2021-10-14 19:19:13,063: xml rpc node: starting XML-RPC server
[roslaunch][INFO] 2021-10-14 19:19:13,075: started roslaunch server http://raspberrypi:33859/
[roslaunch.parent][INFO] 2021-10-14 19:19:13,075: ... parent XML-RPC server started
[roslaunch][INFO] 2021-10-14 19:19:13,079: master.is_running[http://localhost:11311]
[roslaunch][INFO] 2021-10-14 19:19:13,080: auto-starting new master
[roslaunch][INFO] 2021-10-14 19:19:13,081: create_master_process: rosmaster, /opt/ros/kinetic/share/ros, 11311, 3, None
[roslaunch][INFO] 2021-10-14 19:19:13,081: process[master]: launching with args [['rosmaster', '--core', '-p', '11311', '-w', '3']]
[roslaunch.pmon][INFO] 2021-10-14 19:19:13,081: ProcessMonitor.register[master]
[roslaunch.pmon][INFO] 2021-10-14 19:19:13,082: ProcessMonitor.register[master] complete
[roslaunch][INFO] 2021-10-14 19:19:13,082: process[master]: starting os process
[roslaunch][INFO] 2021-10-14 19:19:13,082: process[master]: start w/ args [['rosmaster', '--core', '-p', '11311', '-w', '3', '__log:=/home/pi/.ros/log/d8db13ba-2d12-11ec-9bc7-dca6327f86e2/master.log']]
[roslaunch][INFO] 2021-10-14 19:19:13,082: process[master]: cwd will be [/home/pi/.ros]
[roslaunch][INFO] 2021-10-14 19:19:13,091: process[master]: started with pid [1456]
[roslaunch][INFO] 2021-10-14 19:19:13,092: master.is_running[http://localhost:11311]
[roslaunch][INFO] 2021-10-14 19:19:13,194: master.is_running[http://localhost:11311]
[roslaunch][INFO] 2021-10-14 19:19:13,296: master.is_running[http://localhost:11311]
[roslaunch][INFO] 2021-10-14 19:19:13,397: master.is_running[http://localhost:11311]
[roslaunch][INFO] 2021-10-14 19:19:13,499: master.is_running[http://localhost:11311]
[roslaunch][INFO] 2021-10-14 19:19:13,601: master.is_running[http://localhost:11311]
[roslaunch][INFO] 2021-10-14 19:19:13,702: master.is_running[http://localhost:11311]
[roslaunch][INFO] 2021-10-14 19:19:13,707: master.is_running[http://localhost:11311]
[roslaunch][INFO] 2021-10-14 19:19:13,709: ROS_MASTER_URI=http://localhost:11311
[roslaunch][INFO] 2021-10-14 19:19:13,713: setting /run_id to d8db13ba-2d12-11ec-9bc7-dca6327f86e2
[roslaunch][INFO] 2021-10-14 19:19:13,716: setting /roslaunch/uris/host_raspberrypi__33859' to http://raspberrypi:33859/
[roslaunch][INFO] 2021-10-14 19:19:13,723: ... preparing to launch node of type [rosout/rosout]
[roslaunch][INFO] 2021-10-14 19:19:13,723: create_node_process: package[rosout] type[rosout] machine[Machine(name[] env_loader[None] address[localhost] ssh_port[22] user[None] assignable[True] timeout[10.0])] master_uri[http://localhost:11311]
[roslaunch][INFO] 2021-10-14 19:19:13,723: process[rosout-1]: env[{'NO_AT_BRIDGE': '1', 'ROS_DISTRO': 'kinetic', 'LC_NUMERIC': 'de_DE.UTF-8', 'LESSOPEN': '| /usr/bin/lesspipe %s', 'XDG_SESSION_TYPE': 'tty', 'ROSLISP_PACKAGE_DIRECTORIES': '/home/pi/catkin_ws/devel/share/common-lisp', 'LOGNAME': 'pi', 'USER': 'pi', 'PATH': '/opt/ros/kinetic/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games', 'LC_PAPER': 'de_DE.UTF-8', 'HOME': '/home/pi', 'ROS_PACKAGE_PATH': '/home/pi/catkin_ws:/home/pi/catkin_ws/src/ddynamic_reconfigure:/home/pi/catkin_ws/src/realsense-ros/realsense2_camera:/home/pi/catkin_ws/src/realsense-ros/realsense2_description:/opt/ros/kinetic/share', 'CMAKE_PREFIX_PATH': '/home/pi/catkin_ws/devel:/opt/ros/kinetic', 'ROS_LOG_FILENAME': '/home/pi/.ros/log/d8db13ba-2d12-11ec-9bc7-dca6327f86e2/roslaunch-raspberrypi-1445.log', 'LANG': 'en_US.UTF-8', 'TERM': 'xterm-256color', 'SHELL': '/bin/bash', 'LANGUAGE': 'en_US.UTF-8', 'LC_MEASUREMENT': 'de_DE.UTF-8', 'LESSCLOSE': '/usr/bin/lesspipe %s %s', 'LD_LIBRARY_PATH': '/usr/local/lib:/home/pi/catkin_ws/devel/lib:/home/pi/catkin_ws/devel/lib:/opt/ros/kinetic/lib', 'TEXTDOMAIN': 'Linux-PAM', 'ALIENGO_SDK_PATH': '/home/pi/aliengo_sdk', 'ROS_ETC_DIR': '/opt/ros/kinetic/etc/ros', 'ROS_PYTHON_VERSION': '2', 'XDG_RUNTIME_DIR': '/run/user/1000', 'LC_ADDRESS': 'de_DE.UTF-8', 'PYTHONPATH': '/home/pi/catkin_ws/devel/lib/python2.7/dist-packages:/opt/ros/kinetic/lib/python2.7/dist-packages:/usr/local/lib', 'SHLVL': '1', 'ROS_ROOT': '/opt/ros/kinetic/share/ros', 'PKG_CONFIG_PATH': '/home/pi/catkin_ws/devel/lib/pkgconfig:/opt/ros/kinetic/lib/pkgconfig', 'LC_ALL': 'en_US.UTF-8', 'XDG_SESSION_ID': 'c4', 'DBUS_SESSION_BUS_ADDRESS': 'unix:path=/run/user/1000/bus', '_': '/opt/ros/kinetic/bin/roslaunch', 'LC_IDENTIFICATION': 'de_DE.UTF-8', 'LS_COLORS': 'rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:', 'DISPLAY': 'localhost:11.0', 'UNITREE_LEGGED_SDK_PATH': '/home/pi/unitree_legged_sdk', 'SSH_TTY': '/dev/pts/2', 'SSH_CLIENT': '192.168.123.162 46366 22', 'LC_TELEPHONE': 'de_DE.UTF-8', 'LC_MONETARY': 'de_DE.UTF-8', 'PWD': '/home/pi', 'ROS_MASTER_URI': 'http://localhost:11311', 'XDG_SESSION_CLASS': 'user', 'ROS_VERSION': '1', 'LC_NAME': 'de_DE.UTF-8', 'MAIL': '/var/mail/pi', 'LC_TIME': 'de_DE.UTF-8', 'SSH_CONNECTION': '192.168.123.162 46366 192.168.123.12 22', 'UNITREE_PLATFORM': 'amd64'}]
[roslaunch][INFO] 2021-10-14 19:19:13,825: process[rosout-1]: args[[u'/opt/ros/kinetic/lib/rosout/rosout', u'__name:=rosout']]
[roslaunch][INFO] 2021-10-14 19:19:13,825: ... created process [rosout-1]
[roslaunch.pmon][INFO] 2021-10-14 19:19:13,826: ProcessMonitor.register[rosout-1]
[roslaunch.pmon][INFO] 2021-10-14 19:19:13,826: ProcessMonitor.register[rosout-1] complete
[roslaunch][INFO] 2021-10-14 19:19:13,826: ... registered process [rosout-1]
[roslaunch][INFO] 2021-10-14 19:19:13,826: process[rosout-1]: starting os process
[roslaunch][INFO] 2021-10-14 19:19:13,827: process[rosout-1]: start w/ args [[u'/opt/ros/kinetic/lib/rosout/rosout', u'__name:=rosout', u'__log:=/home/pi/.ros/log/d8db13ba-2d12-11ec-9bc7-dca6327f86e2/rosout-1.log']]
[roslaunch][INFO] 2021-10-14 19:19:13,827: process[rosout-1]: cwd will be [/home/pi/.ros]
[roslaunch][INFO] 2021-10-14 19:19:13,837: process[rosout-1]: started with pid [1469]
[roslaunch][INFO] 2021-10-14 19:19:13,837: ... successfully launched [rosout-1]
[roslaunch][INFO] 2021-10-14 19:19:13,838: load_parameters starting ...
[roslaunch][INFO] 2021-10-14 19:19:13,923: ... load_parameters complete
[roslaunch][INFO] 2021-10-14 19:19:13,923: launch_nodes: launching local nodes ...
[roslaunch][INFO] 2021-10-14 19:19:13,924: ... preparing to launch node of type [nodelet/nodelet]
[roslaunch][INFO] 2021-10-14 19:19:13,924: create_node_process: package[nodelet] type[nodelet] machine[Machine(name[] env_loader[None] address[localhost] ssh_port[22] user[None] assignable[True] timeout[10.0])] master_uri[http://localhost:11311]
[roslaunch][INFO] 2021-10-14 19:19:13,924: process[camera/realsense2_camera_manager-2]: env[{'NO_AT_BRIDGE': '1', 'ROS_DISTRO': 'kinetic', 'LC_NUMERIC': 'de_DE.UTF-8', 'LESSOPEN': '| /usr/bin/lesspipe %s', 'XDG_SESSION_TYPE': 'tty', 'ROSLISP_PACKAGE_DIRECTORIES': '/home/pi/catkin_ws/devel/share/common-lisp', 'LOGNAME': 'pi', 'USER': 'pi', 'PATH': '/opt/ros/kinetic/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games', 'LC_PAPER': 'de_DE.UTF-8', 'HOME': '/home/pi', 'ROS_PACKAGE_PATH': '/home/pi/catkin_ws:/home/pi/catkin_ws/src/ddynamic_reconfigure:/home/pi/catkin_ws/src/realsense-ros/realsense2_camera:/home/pi/catkin_ws/src/realsense-ros/realsense2_description:/opt/ros/kinetic/share', 'CMAKE_PREFIX_PATH': '/home/pi/catkin_ws/devel:/opt/ros/kinetic', 'ROS_LOG_FILENAME': '/home/pi/.ros/log/d8db13ba-2d12-11ec-9bc7-dca6327f86e2/roslaunch-raspberrypi-1445.log', 'LANG': 'en_US.UTF-8', 'TERM': 'xterm-256color', 'SHELL': '/bin/bash', 'LANGUAGE': 'en_US.UTF-8', 'LC_MEASUREMENT': 'de_DE.UTF-8', 'LESSCLOSE': '/usr/bin/lesspipe %s %s', 'LD_LIBRARY_PATH': '/usr/local/lib:/home/pi/catkin_ws/devel/lib:/home/pi/catkin_ws/devel/lib:/opt/ros/kinetic/lib', 'TEXTDOMAIN': 'Linux-PAM', 'ALIENGO_SDK_PATH': '/home/pi/aliengo_sdk', 'ROS_ETC_DIR': '/opt/ros/kinetic/etc/ros', 'ROS_PYTHON_VERSION': '2', 'XDG_RUNTIME_DIR': '/run/user/1000', 'LC_ADDRESS': 'de_DE.UTF-8', 'PYTHONPATH': '/home/pi/catkin_ws/devel/lib/python2.7/dist-packages:/opt/ros/kinetic/lib/python2.7/dist-packages:/usr/local/lib', 'SHLVL': '1', 'ROS_NAMESPACE': u'/camera', 'ROS_ROOT': '/opt/ros/kinetic/share/ros', 'PKG_CONFIG_PATH': '/home/pi/catkin_ws/devel/lib/pkgconfig:/opt/ros/kinetic/lib/pkgconfig', 'LC_ALL': 'en_US.UTF-8', 'XDG_SESSION_ID': 'c4', 'DBUS_SESSION_BUS_ADDRESS': 'unix:path=/run/user/1000/bus', '_': '/opt/ros/kinetic/bin/roslaunch', 'LC_IDENTIFICATION': 'de_DE.UTF-8', 'LS_COLORS': 'rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:', 'DISPLAY': 'localhost:11.0', 'UNITREE_LEGGED_SDK_PATH': '/home/pi/unitree_legged_sdk', 'SSH_TTY': '/dev/pts/2', 'SSH_CLIENT': '192.168.123.162 46366 22', 'LC_TELEPHONE': 'de_DE.UTF-8', 'LC_MONETARY': 'de_DE.UTF-8', 'PWD': '/home/pi', 'ROS_MASTER_URI': 'http://localhost:11311', 'XDG_SESSION_CLASS': 'user', 'ROS_VERSION': '1', 'LC_NAME': 'de_DE.UTF-8', 'MAIL': '/var/mail/pi', 'LC_TIME': 'de_DE.UTF-8', 'SSH_CONNECTION': '192.168.123.162 46366 192.168.123.12 22', 'UNITREE_PLATFORM': 'amd64'}]
[roslaunch][INFO] 2021-10-14 19:19:13,927: process[camera/realsense2_camera_manager-2]: args[[u'/opt/ros/kinetic/lib/nodelet/nodelet', 'manager', u'__name:=realsense2_camera_manager']]
[roslaunch][INFO] 2021-10-14 19:19:13,927: ... created process [camera/realsense2_camera_manager-2]
[roslaunch.pmon][INFO] 2021-10-14 19:19:13,928: ProcessMonitor.register[camera/realsense2_camera_manager-2]
[roslaunch.pmon][INFO] 2021-10-14 19:19:13,928: ProcessMonitor.register[camera/realsense2_camera_manager-2] complete
[roslaunch][INFO] 2021-10-14 19:19:13,928: ... registered process [camera/realsense2_camera_manager-2]
[roslaunch][INFO] 2021-10-14 19:19:13,928: process[camera/realsense2_camera_manager-2]: starting os process
[roslaunch][INFO] 2021-10-14 19:19:13,929: process[camera/realsense2_camera_manager-2]: start w/ args [[u'/opt/ros/kinetic/lib/nodelet/nodelet', 'manager', u'__name:=realsense2_camera_manager', u'__log:=/home/pi/.ros/log/d8db13ba-2d12-11ec-9bc7-dca6327f86e2/camera-realsense2_camera_manager-2.log']]
[roslaunch][INFO] 2021-10-14 19:19:13,929: process[camera/realsense2_camera_manager-2]: cwd will be [/home/pi/.ros]
[roslaunch][INFO] 2021-10-14 19:19:13,938: process[camera/realsense2_camera_manager-2]: started with pid [1486]
[roslaunch][INFO] 2021-10-14 19:19:13,939: ... successfully launched [camera/realsense2_camera_manager-2]
[roslaunch][INFO] 2021-10-14 19:19:13,939: ... preparing to launch node of type [nodelet/nodelet]
[roslaunch][INFO] 2021-10-14 19:19:13,940: create_node_process: package[nodelet] type[nodelet] machine[Machine(name[] env_loader[None] address[localhost] ssh_port[22] user[None] assignable[True] timeout[10.0])] master_uri[http://localhost:11311]
[roslaunch][INFO] 2021-10-14 19:19:13,940: process[camera/realsense2_camera-3]: env[{'NO_AT_BRIDGE': '1', 'ROS_DISTRO': 'kinetic', 'LC_NUMERIC': 'de_DE.UTF-8', 'LESSOPEN': '| /usr/bin/lesspipe %s', 'XDG_SESSION_TYPE': 'tty', 'ROSLISP_PACKAGE_DIRECTORIES': '/home/pi/catkin_ws/devel/share/common-lisp', 'LOGNAME': 'pi', 'USER': 'pi', 'PATH': '/opt/ros/kinetic/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games', 'LC_PAPER': 'de_DE.UTF-8', 'HOME': '/home/pi', 'ROS_PACKAGE_PATH': '/home/pi/catkin_ws:/home/pi/catkin_ws/src/ddynamic_reconfigure:/home/pi/catkin_ws/src/realsense-ros/realsense2_camera:/home/pi/catkin_ws/src/realsense-ros/realsense2_description:/opt/ros/kinetic/share', 'CMAKE_PREFIX_PATH': '/home/pi/catkin_ws/devel:/opt/ros/kinetic', 'ROS_LOG_FILENAME': '/home/pi/.ros/log/d8db13ba-2d12-11ec-9bc7-dca6327f86e2/roslaunch-raspberrypi-1445.log', 'LANG': 'en_US.UTF-8', 'TERM': 'xterm-256color', 'SHELL': '/bin/bash', 'LANGUAGE': 'en_US.UTF-8', 'LC_MEASUREMENT': 'de_DE.UTF-8', 'LESSCLOSE': '/usr/bin/lesspipe %s %s', 'LD_LIBRARY_PATH': '/usr/local/lib:/home/pi/catkin_ws/devel/lib:/home/pi/catkin_ws/devel/lib:/opt/ros/kinetic/lib', 'TEXTDOMAIN': 'Linux-PAM', 'ALIENGO_SDK_PATH': '/home/pi/aliengo_sdk', 'ROS_ETC_DIR': '/opt/ros/kinetic/etc/ros', 'ROS_PYTHON_VERSION': '2', 'XDG_RUNTIME_DIR': '/run/user/1000', 'LC_ADDRESS': 'de_DE.UTF-8', 'PYTHONPATH': '/home/pi/catkin_ws/devel/lib/python2.7/dist-packages:/opt/ros/kinetic/lib/python2.7/dist-packages:/usr/local/lib', 'SHLVL': '1', 'ROS_NAMESPACE': u'/camera', 'ROS_ROOT': '/opt/ros/kinetic/share/ros', 'PKG_CONFIG_PATH': '/home/pi/catkin_ws/devel/lib/pkgconfig:/opt/ros/kinetic/lib/pkgconfig', 'LC_ALL': 'en_US.UTF-8', 'XDG_SESSION_ID': 'c4', 'DBUS_SESSION_BUS_ADDRESS': 'unix:path=/run/user/1000/bus', '_': '/opt/ros/kinetic/bin/roslaunch', 'LC_IDENTIFICATION': 'de_DE.UTF-8', 'LS_COLORS': 'rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:', 'DISPLAY': 'localhost:11.0', 'UNITREE_LEGGED_SDK_PATH': '/home/pi/unitree_legged_sdk', 'SSH_TTY': '/dev/pts/2', 'SSH_CLIENT': '192.168.123.162 46366 22', 'LC_TELEPHONE': 'de_DE.UTF-8', 'LC_MONETARY': 'de_DE.UTF-8', 'PWD': '/home/pi', 'ROS_MASTER_URI': 'http://localhost:11311', 'XDG_SESSION_CLASS': 'user', 'ROS_VERSION': '1', 'LC_NAME': 'de_DE.UTF-8', 'MAIL': '/var/mail/pi', 'LC_TIME': 'de_DE.UTF-8', 'SSH_CONNECTION': '192.168.123.162 46366 192.168.123.12 22', 'UNITREE_PLATFORM': 'amd64'}]
[roslaunch][INFO] 2021-10-14 19:19:13,944: process[camera/realsense2_camera-3]: args[[u'/opt/ros/kinetic/lib/nodelet/nodelet', 'load', 'realsense2_camera/RealSenseNodeFactory', 'realsense2_camera_manager', u'__name:=realsense2_camera']]
[roslaunch][INFO] 2021-10-14 19:19:13,944: ... created process [camera/realsense2_camera-3]
[roslaunch.pmon][INFO] 2021-10-14 19:19:13,945: ProcessMonitor.register[camera/realsense2_camera-3]
[roslaunch.pmon][INFO] 2021-10-14 19:19:13,945: ProcessMonitor.register[camera/realsense2_camera-3] complete
[roslaunch][INFO] 2021-10-14 19:19:13,945: ... registered process [camera/realsense2_camera-3]
[roslaunch][INFO] 2021-10-14 19:19:13,945: process[camera/realsense2_camera-3]: starting os process
[roslaunch][INFO] 2021-10-14 19:19:13,946: process[camera/realsense2_camera-3]: start w/ args [[u'/opt/ros/kinetic/lib/nodelet/nodelet', 'load', 'realsense2_camera/RealSenseNodeFactory', 'realsense2_camera_manager', u'__name:=realsense2_camera', u'__log:=/home/pi/.ros/log/d8db13ba-2d12-11ec-9bc7-dca6327f86e2/camera-realsense2_camera-3.log']]
[roslaunch][INFO] 2021-10-14 19:19:13,946: process[camera/realsense2_camera-3]: cwd will be [/home/pi/.ros]
[roslaunch][INFO] 2021-10-14 19:19:13,956: process[camera/realsense2_camera-3]: started with pid [1487]
[roslaunch][INFO] 2021-10-14 19:19:13,957: ... successfully launched [camera/realsense2_camera-3]
[roslaunch][INFO] 2021-10-14 19:19:13,958: ... launch_nodes complete
[roslaunch.pmon][INFO] 2021-10-14 19:19:13,958: registrations completed <ProcessMonitor(ProcessMonitor-1, started daemon -1245277088)>
[roslaunch.parent][INFO] 2021-10-14 19:19:13,958: ... roslaunch parent running, waiting for process exit
[roslaunch][INFO] 2021-10-14 19:19:13,959: spin
[roslaunch][ERROR] 2021-10-14 19:19:28,601: [camera/realsense2_camera_manager-2] process has died [pid 1486, exit code -6, cmd /opt/ros/kinetic/lib/nodelet/nodelet manager __name:=realsense2_camera_manager __log:=/home/pi/.ros/log/d8db13ba-2d12-11ec-9bc7-dca6327f86e2/camera-realsense2_camera_manager-2.log].
log file: /home/pi/.ros/log/d8db13ba-2d12-11ec-9bc7-dca6327f86e2/camera-realsense2_camera_manager-2*.log
[roslaunch.pmon][INFO] 2021-10-14 19:19:28,602: ProcessMonitor.unregister[camera/realsense2_camera_manager-2] starting
[roslaunch.pmon][INFO] 2021-10-14 19:19:28,602: ProcessMonitor.unregister[camera/realsense2_camera_manager-2] complete
[roslaunch][INFO] 2021-10-14 19:19:32,211: [camera/realsense2_camera-3] process has finished cleanly
log file: /home/pi/.ros/log/d8db13ba-2d12-11ec-9bc7-dca6327f86e2/camera-realsense2_camera-3*.log
[roslaunch.pmon][INFO] 2021-10-14 19:19:32,212: ProcessMonitor.unregister[camera/realsense2_camera-3] starting
[roslaunch.pmon][INFO] 2021-10-14 19:19:32,212: ProcessMonitor.unregister[camera/realsense2_camera-3] complete
[roslaunch.pmon][INFO] 2021-10-14 19:31:37,737: ProcessMonitor.shutdown <ProcessMonitor(ProcessMonitor-1, started daemon -1245277088)>
[roslaunch.pmon][INFO] 2021-10-14 19:31:37,741: ProcessMonitor._post_run <ProcessMonitor(ProcessMonitor-1, started daemon -1245277088)>
[roslaunch.pmon][INFO] 2021-10-14 19:31:37,742: ProcessMonitor._post_run <ProcessMonitor(ProcessMonitor-1, started daemon -1245277088)>: remaining procs are [<roslaunch.nodeprocess.LocalProcess object at 0xb5d46b50>, <roslaunch.nodeprocess.LocalProcess object at 0xb5cf23b0>]
[roslaunch.pmon][INFO] 2021-10-14 19:31:37,748: ProcessMonitor exit: killing rosout-1
[roslaunch][INFO] 2021-10-14 19:31:37,749: [rosout-1] killing on exit
[roslaunch][INFO] 2021-10-14 19:31:37,750: process[rosout-1]: killing os process with pid[1469] pgid[1469]
[roslaunch][INFO] 2021-10-14 19:31:37,751: [rosout-1] sending SIGINT to pgid [1469]
[roslaunch][INFO] 2021-10-14 19:31:37,751: [rosout-1] sent SIGINT to pgid [1469]
[roslaunch][INFO] 2021-10-14 19:31:38,052: process[rosout-1]: SIGINT killed with return value 0
[roslaunch.pmon][INFO] 2021-10-14 19:31:38,053: ProcessMonitor exit: killing master
[roslaunch][INFO] 2021-10-14 19:31:38,053: [master] killing on exit
[roslaunch][INFO] 2021-10-14 19:31:38,053: process[master]: killing os process with pid[1456] pgid[1456]
[roslaunch][INFO] 2021-10-14 19:31:38,053: [master] sending SIGINT to pgid [1456]
[roslaunch][INFO] 2021-10-14 19:31:38,054: [master] sent SIGINT to pgid [1456]
[roslaunch][INFO] 2021-10-14 19:31:38,254: process[master]: SIGINT killed with return value 0
[roslaunch.pmon][INFO] 2021-10-14 19:31:38,255: ProcessMonitor exit: cleaning up data structures and signals
[roslaunch.pmon][INFO] 2021-10-14 19:31:38,255: ProcessMonitor exit: pmon has shutdown
[roslaunch][INFO] 2021-10-14 19:31:38,303: process monitor is done spinning, initiating full shutdown
[roslaunch][INFO] 2021-10-14 19:31:38,303: runner.stop()
[roslaunch][INFO] 2021-10-14 19:31:38,304: shutting down processing monitor...
[roslaunch][INFO] 2021-10-14 19:31:38,304: shutting down processing monitor <ProcessMonitor(ProcessMonitor-1, stopped daemon -1245277088)>
[roslaunch.pmon][INFO] 2021-10-14 19:31:38,304: ProcessMonitor.shutdown <ProcessMonitor(ProcessMonitor-1, stopped daemon -1245277088)>
[roslaunch][INFO] 2021-10-14 19:31:38,304: ... shutting down processing monitor complete
[roslaunch][INFO] 2021-10-14 19:31:38,304: done
[roslaunch.pmon][INFO] 2021-10-14 19:31:38,305: ProcessMonitor.shutdown <ProcessMonitor(ProcessMonitor-1, stopped daemon -1245277088)>
[rospy.core][INFO] 2021-10-14 19:31:38,305: signal_shutdown [atexit]
