The R1 Basic/EDU documentation mentions a binocular depth camera with approximately 150° horizontal FOV, depth output at 544×448 @ 10 Hz and RGB at 1280×1088 @ 30 Hz.
However, on our R1 we can currently access only a single monocular H.264 RTSP stream at 192.168.123.161:8551.
We cannot find a stereo pair or depth stream.
Could you please clarify:
- Does our R1 have the binocular depth camera installed?
- If yes, how can we access the depth data?
- Is there a specific IP address, RTSP stream, DDS topic, SDK interface or service for the depth camera?
- Is any additional software or driver required?
Thank you for the detailed question. We checked this on our own R1 EDU, and here is what we can confirm.
Is the binocular depth camera installed?
Yes. Every R1 Basic and R1 EDU ships with the binocular depth module in the head. Only the R1 AIR has a monocular camera. If your unit is a Basic or EDU, the stereo hardware is present.
Why you only see one monocular stream
The camera module is wired to PC1, the main control board at 192.168.123.161, not to the Jetson development board. PC1 runs Unitree’s closed firmware, and on the current release it exports exactly one RGB feed from the camera. That feed is available in three forms, all carrying the same single image:
- the RTSP stream at 192.168.123.161:8551 that you found,
- an H.264 multicast stream on 230.1.1.1:1720 (1280x720 at 30 fps),
- the videohub DDS service, API id 1001 GetImageSample, which returns a JPEG of the same frame.
We scanned the full DDS topic list on the robot. There is no left or right image topic, no disparity topic and no depth topic. The 544x448 depth output listed in the datasheet is used internally by Unitree’s own perception stack on PC1 and is not published to developers on the current firmware.
Is there a separate IP, stream, topic or SDK interface for depth?
Not on the current firmware. The Unitree SDK2 contains no depth or stereo client for the R1. The only R1 clients are locomotion, arm actions and audio.
Is additional software or a driver required?
No driver on your side can expose the depth data, because the camera is not reachable from the Jetson. Access depends on Unitree publishing it from PC1 in a future firmware.
