Go2 edu Lidar Data
Hi all,
On a recent attempt to ssh on a edu go2 quadruped, access denied showing port 22 denial.
Tried the following:
RJ45 connection, standard network configuration in the same network, with standard usernames/passwords, even using an ip/port scanner.
cyclone dds… over ROS2 can list all functions
but ssh over terminal could not connect,
Also tried to use the usb c with HDMI and keyboard/mouse there was no signal detected.
The purpose is to configure/find out where the app on the mobile saves the lidar data.
Any help would be appreciated,
Yours faithfully,
Manos
