Error: Set affinity failed
i’m trying to follow the instructions on the docs to run high_level_mode on the a1. I’ve connected a PC via LAN and can ssh into the rasberry pi. When typing roslaunch mbs_unitree_ros high_level_mode.launch the following error occurs: Error: Set affinity failed.
The full response:
... logging to /home/felix/.ros/log/4316c64c-4623-11ec-8e83-00155d380107/roslaunch-felix-Virtual-Machine-1539.log
Press Ctrl-C to interrupt
started roslaunch server http://felix-Virtual-Machine:46849/
SUMMARY
PARAMETERS
 * /control_level: highlevel
 * /firmwork: 3_2
 * /robot_name: a1
 * /rosdistro: melodic
 * /rosversion: 1.14.12
NODES
    high_level_driver (mbs_unitree_ros/high_level_mode)
    node_lcm_server (unitree_legged_real/lcm_server_3_2)
auto-starting new master
process[master]: started with pid [1550]
ROS_MASTER_URI=http://localhost:11311
setting /run_id to 4316c64c-4623-11ec-8e83-00155d380107
process[rosout-1]: started with pid [1561]
started core service [/rosout]
process[node_lcm_server-2]: started with pid [1564]
process[high_level_driver-3]: started with pid [1565]
UDP Initialized. Port: 8080
LCM Initialized. Subscribe channel: LCM_High_Cmd, Publish channel: LCM_High_State
[Loop Start] named: UDP_Send, period: 2(ms), run at cpu: 3
[node_lcm_server-2] process has died [pid 1564, exit code 254, cmd /home/felix/catkin_ws/devel/lib/unitree_legged_real/lcm_server_3_2 a1 highlevel __name:=node_lcm_server __log:=/home/felix/.ros/log/4316c64c-4623-11ec-8e83-00155d380107/node_lcm_server-2.log].
log file: /home/felix/.ros/log/4316c64c-4623-11ec-8e83-00155d380107/node_lcm_server-2*.log
[high_level_driver-3] process has died [pid 1565, exit code 254, cmd /home/felix/catkin_ws/devel/lib/mbs_unitree_ros/high_level_mode __name:=high_level_driver __log:=/home/felix/.ros/log/4316c64c-4623-11ec-8e83-00155d380107/high_level_driver-3.log].
log file: /home/felix/.ros/log/4316c64c-4623-11ec-8e83-00155d380107/high_level_driver-3*.log
I’m running Ubuntu 18.04 on Hyper-V. Can this be the problem? If yes, what VM service do you recommend?
Thank you for your time,
Felix
Hi Felix,
Are you running your source code on Rasberry Pi or on your VM?
I have never used this with VM.
HI,
I was running it on my remote PC on a VM (Hyper-V). I resolved the issue by running it on WSL. I thought I can only run the High_Level_Mode node on a remote PC. Can I also run it on the Rasberry Pi in the robot?
I think running it on a RPI should not be a problem.
