Hi everybody,
I am trying to set up outdoor GPS waypoint navigation on a Jackal robot. I am using ROS2 Humble, and the robot is equipped with an Ouster LiDAR and the standard Jackal GPS.
By following the NAV2 tutorials, I tried to set up a dual EKF for precise localization and the NavSat Transform Node.
config .yaml file:
# For parameter descriptions, please refer to the template parameter files for each node.
ekf_filter_node_odom:
ros__parameters:
frequency: 30.0
sensor_timeout: 0.1
two_d_mode: true # Recommended to use 2d mode for nav2 in mostly planar environments
transform_time_offset: 0.0
transform_timeout: 0.0
print_diagnostics: true
debug: true
publish_tf: true
map_frame: map
odom_frame: odom
base_link_frame: base_link # the frame id used by the turtlebot's diff drive plugin
world_frame: odom
odom0: j100_0538/platform/odom
odom0_config: [false, false, false,
true, true, true,
false, false, false]
odom0_queue_size: 10
odom0_nodelay: true
odom0_differential: false
odom0_relative: false
imu0: j100_0538/sensors/imu_0/data
imu0_config: [false, false, false,
true, true, false,
true, true, true,
true, true, true]
imu0_nodelay: false
imu0_differential: true # If using a real robot you might want to set this to true, since usually absolute measurements from real imu's are not very accurate
imu0_relative: false
imu0_queue_size: 10
imu0_remove_gravitational_acceleration: true
use_control: false
process_noise_covariance: [1e-3, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 1e-3, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 1e-3, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.3, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.3, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.01, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.5, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.5, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.1, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.3, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.3, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.3, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.3, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.3, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.3]
ekf_filter_node_map:
ros__parameters:
frequency: 30.0
sensor_timeout: 0.1
debug: false
publish_tf: true
map_frame: map
odom_frame: odom
world_frame: map
true, true, true,
false, false, true,
odom0_nodelay: true
odom1: j100_0538/odometry/gps
odom1_config: [true, true, false,
odom1_queue_size: 10
odom1_nodelay: true
odom1_differential: false
odom1_relative: false
true, true, false,
true, true, true,
true, true, true]
imu0_nodelay: true
imu0_queue_size: 10
use_control: false
process_noise_covariance: [1.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 1.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,
0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, .0, 0.3]
navsat_transform:
ros__parameters:
frequency: 30.0
delay: 3.0
magnetic_declination_radians: 0.05585
yaw_offset: 0.0
zero_altitude: true
broadcast_cartesian_transform: true
publish_filtered_gps: true
use_odometry_yaw: true
wait_for_datum: false
Launch file:
from launch import LaunchDescription
from ament_index_python.packages import get_package_share_directory
from launch.actions import IncludeLaunchDescription
from launch.launch_description_sources import PythonLaunchDescriptionSource
import launch_ros.actions
import os
import launch.actions
def generate_launch_description():
gps_wpf_dir = get_package_share_directory(
"nav2_gps_waypoint_follower_demo")
rl_params_file = os.path.join(
gps_wpf_dir, "config", "dual_ekf_navsat_params.yaml")
return LaunchDescription(
launch.actions.DeclareLaunchArgument(
"output_final_position", default_value="false"
"output_location", default_value="~/dual_ekf_navsat_example_debug.txt"
launch_ros.actions.Node(
package="robot_localization",
executable="ekf_node",
name="ekf_filter_node_odom",
output="screen",
parameters=[rl_params_file, {"use_sim_time": False}],
remappings=[("odometry/filtered", "j100_0538/odometry/local"),
("/tf", "j100_0538/tf"),
("/tf_static", "j100_0538/tf_static")],
name="ekf_filter_node_map",
output="screen",
remappings=[("odometry/filtered", "j100_0538/odometry/global"),
executable="navsat_transform_node",
name="navsat_transform",
output="screen",
remappings=[
("imu/data", "j100_0538/sensors/imu_0/data"),
("gps/fix", "j100_0538/sensors/gps_0/fix"),
("gps/filtered", "j100_0538/gps/filtered"),
("odometry/gps", "j100_0538/odometry/gps"),
the robot is fully namespaced so I also wanted to output topics to be namespaced.
Could someone please review my configuration and let me know if it looks good for my application? Any tips or suggestions for improvement would be greatly appreciated!
Thank you!
