[Clearpath Husky A200] Custom Sensor Fusion
Dear Support,
I am trying to run the ekf_node in a custom launch file and use a custom localization.yaml file for sensor fusion. To do this, I have already disabled the ekf_node by setting the enable_ekf parameter to false in the following launch files:
  • /opt/ros/humble/share/clearpath_common/launch/platform.launch.py
  • /opt/ros/humble/share/clearpath_control/launch/localization.launch.py
Despite this modification, the ekf_node is launched after every robot system boot. It seems there is a Clearpath service that ignores the changes in the launch files mentioned above and starts the node automatically.
Thank you.
Instead of disabling, just comment out their ekf node in their launch description.
  • Disable the clearpath_control localization as it is missing imu. It is disabled in or package but must be disabled in theirs as well:
    • sudo nano /opt/ros/humble/share/clearpath_platform/launch/platform.launch.py
    • Disable these
    #IncludeLaunchDescription(
            #    PythonLaunchDescriptionSource(launch_file_localization),
            #    launch_arguments=[
            #        ('setup_path', setup_path),
            #        ('use_sim_time', use_sim_time)]
Thanky you, the modificaton worked. In my case the launch file is in
