Hi! I have a AK80-64 motor with the driver 2.0, but the driver runs only after the connection with the st-link software. Without the connection to the ST-link the driver won’t boot.
There is a solution to this problem?
Hi Mik
We can sent the firmware with boot to you. You can use st-link to refresh the firmware into the V2.0 board. Then you can boot from our Cubemars tool or change the mode.
Pls give us your email box. I will send to you via email.
