Hi, I am looking for help about use servo mode on arduino. That is my code which I used:
#include <mcp2515_can.h>
#include <SPI.h>
/*SAMD core*/
#ifdef ARDUINO_SAMD_VARIANT_COMPLIANCE
#define SERIAL SerialUSB
#else
#endif
mcp2515_can CAN(10);
const float MAX_PWM = 100000.0f;
const float MAX_CURRENT = 60000.0f;
const float MAX_VELOCITY = 100000.0f;
const float MAX_POSITION = 360000000.0f;
const float MAX_POSITION_VELOCITY = 32767.0f;
const float MIN_POSITION_VELOCITY = -32768.0f;
const float MAX_ACCELERATION = 400000.0f;
enum AKMode {
AK_PWM = 0,
AK_CURRENT,
AK_CURRENT_BRAKE,
AK_VELOCITY,
AK_POSITION,
AK_ORIGIN,
AK_POSITION_VELOCITY,
uint32_t canId(int id, AKMode Mode_set) {
uint32_t mode;
mode = Mode_set;
return uint32_t(id | mode << 8);
void comm_can_transmit_eid(uint32_t id, const uint8_t* data, uint8_t len) {
uint8_t i = 0;
if (len > 8) {
len = 8;
uint8_t buf[len];
for (i = 0; i < len; i++) {
buf[i] = data[i];
CAN.sendMsgBuf(id, 1, len, buf);
void buffer_append_int32(uint8_t* buffer, int32_t number, int32_t* index) {
buffer[(*index)++] = number >> 24;
buffer[(*index)++] = number >> 16;
buffer[(*index)++] = number >> 8;
buffer[(*index)++] = number;
void buffer_append_int16(uint8_t* buffer, int16_t number, int16_t* index) {
void comm_can_set_duty(uint8_t controller_id, float duty) {
int32_t send_index = 0;
uint8_t buffer[4];
buffer_append_int32(buffer, (int32_t)(duty * 100000.0), &send_index);
comm_can_transmit_eid(canId(controller_id, AKMode::AK_PWM), buffer, send_index);
void comm_can_set_current(uint8_t controller_id, float current) {
uint8_t buffer[4];
buffer_append_int32(buffer, (int32_t)(current * 1000.0), &send_index);
comm_can_transmit_eid(canId(controller_id, AKMode::AK_CURRENT), buffer, send_index);
void comm_can_set_cb(uint8_t controller_id, float current) {
uint8_t buffer[4];
comm_can_transmit_eid(canId(controller_id, AKMode::AK_CURRENT_BRAKE), buffer, send_index);
void comm_can_set_rpm(uint8_t controller_id, float rpm) {
uint8_t buffer[4];
buffer_append_int32(buffer, (int32_t)rpm, &send_index);
comm_can_transmit_eid(canId(controller_id, AKMode::AK_VELOCITY), buffer, send_index);
void comm_can_set_pos(uint8_t controller_id, float pos) {
uint8_t buffer[4];
buffer_append_int32(buffer, (int32_t)(pos * 1000000.0), &send_index);
comm_can_transmit_eid(canId(controller_id, AKMode::AK_POSITION), buffer, send_index);
void comm_can_set_origin(uint8_t controller_id, uint8_t set_origin_mode) {
uint8_t buffer[4];
comm_can_transmit_eid(canId(controller_id, AKMode::AK_ORIGIN), buffer, send_index);
void comm_can_set_pos_spd(uint8_t controller_id, float pos, int16_t spd, int16_t RPA) {
int16_t send_index1 = 0;
uint8_t buffer[4];
buffer_append_int32(buffer, (int32_t)(pos * 10000.0), &send_index);
buffer_append_int16(buffer, spd, &send_index1);
buffer_append_int16(buffer, RPA, &send_index1);
comm_can_transmit_eid(canId(controller_id, AKMode::AK_POSITION_VELOCITY), buffer, send_index);
void motor_receive(float* motor_pos, float* motor_spd, float* motor_cur, int8_t* motor_temp, int8_t* motor_error, uint8_t* rx_message) {
byte len = 0;
byte buf[8];
unsigned long canId;
CAN.readMsgBuf(&len, buf);
int16_t pos_int = buf[0] << 8 | buf[1];
int16_t spd_int = buf[2] << 8 | buf[3];
int16_t cur_int = buf[4] << 8 | buf[5];
*motor_pos = (float)(pos_int * 0.1f);
*motor_spd = (float)(spd_int * 10.0f);
*motor_cur = (float)(cur_int * 0.01f);
*motor_temp = buf[6];
*motor_error = buf[7];
void setup() {
Serial.begin(115200);
while (!Serial) {};
while (CAN_OK != CAN.begin(CAN_1000KBPS)) { // init can bus : baudrate = 1000k
Serial.println("CAN BUS Shield init fail");
Serial.println(" Init CAN BUS Shield again");
delay(100);
Serial.println("CAN init ok!");
void loop() {
char rc;
rc = Serial.read();
Serial.println(rc);
delay(100);
if (rc == 'x') {
comm_can_set_rpm(0x01, 50000.0);
SERIAL.print("deneme");
if (rc == 's') {
comm_can_set_rpm(0x01, 0);
SERIAL.print("durdu");
What can be wrong? Can anybody help me?
And also is there any code which i can use?
Thanks
