Turtlebot3 burger battery removal
#1
I have assembled my turtlebot3 burger now according to Manual but I don’t see how I should be able to remove the battery without using a screwdriver.
In the Manual at page 4 D.1 there are clear instructions on how remove battery without screwdriver however on page 19 second layer assembly you have clear instructions to nail screws into top wheel/engine.
Also the video here follows the same steps.
Have I assembled the bot wrong or do I have to use screwdriver to remove battery?
Thanks
#2
Dear Can,
in my opinion the easiest way to remove the battery is to dismount the Brackets on the backside
TB3_Bracket
and extract the battery between the two spacers. In that case you should be able remove the battery without using a screwdriver.
Have a nice weekend and lot of fun working on your TB3 :robot:
#3
That is a good idea :slight_smile:
Thanks
