How to execute repetitive programs BCNC?
With “fagor” controleer an example of programmation would be:
N0G17T1S500
N10X0Y2025
N20G91G1Z0F500
N30Z-1F100
N50G90G0Z2
N60X50
N70G25N20.60.2
N80X0Y-50
N90G25N20.70.1
N100X0Y-100
N110G25N20.70.1
N120M30
With program MACH3 the code M47 repeat program. We add the draw of our work.
¿How we can make a repetitive program with controleer BCNC?
And in this program, ¿how can we number the program lines?
Can we take advantage of the “exits” inputs-outputs of the raspberry?
Is it possible to find an extensed manual with programming examples?
With the raspberry and the protoneer plate, ¿can we operate servo motors with the same pulses that we use for stepper motor?
Thank you so much for your help,
Toni
Dear Toni,
bCNC is only a controller. You can send Gcodes over the command line, or create .gcode files with Notepad or something similar on your own.
Its completely Open Source, so I would recommend checking the github repository: GitHub - vlachoudis/bCNC: GRBL CNC command sender, autoleveler and g-code editor
Do you mean PWM Servos like that one, right? https://amzn.to/2JRUrk4
The A4988 or DRV8825 Stepper Drivers were not designed to do so but if you have an oscilloscope you would be able to create a PWM Signal which is controling a Servo, but I would recommend using an unused pin of the Atmega which is still soldered on the board and modifying the GRBL Firmware or using one of the RPi GPIOs.
