Arduino Atmega32u4 A9 GPRS/GSM/GPS
What do you think about feeding the board with an USB 5V 2A from a power supplier such as
Anker PowerPort 6 Indoor Black mobile device charger - Mobile Device Chargers (Indoor, Universal, AC, CE, FCC, UL, Black, 100 - 240)
and connetcing the board to USB splitter Y
With the Red connector to the power supplier and the Black one to the PC running Arduino IDE and the micro connector to the board.
Thanks for your attention.
Hi Oscargolf,
to use a Y-Kabel should be possible.
Another solution could be the use of a active hub, with a external power supply.
Kind regards
MYBOTSHOP Support
